coq-club - Re: [Coq-Club] Typeclass hints and rewrite
  • To: Jason Gross <jasongross9 AT gmail.com>
  • Cc: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Typeclass hints and rewrite
  • Date: Fri, 22 Mar 2013 11:43:03 +0100
Hi Jason,
Le 22 mars 2013 à 05:32, Jason Gross
a écrit :
> Hint Rewrite @FIdentityOf using eauto with typeclass_instances : functor.
> Fail rewrite @FIdentityOf by auto with typeclass_instances. (* should not
> fail *)
> erewrite @FIdentityOf by auto with typeclass_instances.
The problem is that, even before launching type class resolution, [rewrite]
expects
the metavariables for H and H0 to be instantiated, that's why it fails. If
instead it
used existential variables (like [setoid_rewrite FIdentityOf] does) it
wouldn't fail.
There is an (undocumented) tactic [rewrite_db hintdb] which does setoid
rewrite
using the rewrite hint database hintdb, but it doesn't take care of the side
condition tactic (yet). You could still use it like this:
Require Import Setoid.
Ltac rewrite_cat := rewrite_db functor; try typeclasses eauto.
And use rewrite_cat instead of your autorewrite.
-- Matthieu
