coq-club - [Coq-Club] Structural recusrion via minimum
  • To: coq-club AT inria.fr
  • Subject: [Coq-Club] Structural recusrion via minimum
  • Date: Fri, 22 Mar 2013 20:26:09 +0100
Hi,
I would like to share a little trick to make recursive functions structurally recursive.
Consider the gcd function, that ideally, we would like to write as
Fixpoint gcd (m n : nat) : nat :=
match m with
| 0 => n
| _ => gcd (modulo n m) m
end.
However, Coq does not accept this definition because the term (modulo n m) is not structurally smaller than m, altough it is a smaller number. We can circumvent this problem by constructing a term that is equal to (mod n m) and and structurally smaller than m. All we need is the minimum function, defined as follows.
Definition tmin m n := m - (m - n).
Using the fact that the minus from the standard library is defined in a way that the term (m-n) is always structurally smaller or equal than m, we have that the term (tmin m n) is strucurally smaller or equal than m.
Now the following definition of gcd works, even if modulo is left abstract and cannot be inspected by the type checker.
Variable modulo : nat -> nat -> nat.
match m with
| 0 => n
| S m' => gcd (tmin m' (modulo n m)) m
end.
In contrast to this, the structurally recursive versions of gcd in the Coq Standard Library (8.4) and SSReflect use special mod functions.
In proofs about functions using tmin, one just has to rewrite with the following fact.
Lemma tmin_snd m n : n <= m -> tmin m n = n.
Proof.
unfold tmin. omega.
Qed.
This trick allows to write any recursive function that decreases a natural number argument. It could be extended to tree-like inductive types. In this case, instead of the minimum function, one has to search for a given subtree in a larger tree and return it.
Please let me know if this trick has been used before.
Best,
Tobias
