coq-club - [Coq-Club] Type error on [admit] after [simpl in *]?
  • To: coq-club <coq-club AT inria.fr>
  • Subject: [Coq-Club] Type error on [admit] after [simpl in *]?
  • Date: Sun, 31 Mar 2013 11:22:17 -0400
Hi,
I have a goal for which [admit] succeeds, but [simpl in *; admit] fails with a type error, but [simpl in *; hnf in *; admit] succeeds.
All three used to work fine, but then I changed
Arguments Object {obj%type} !C%category / : rename.
to
Arguments Object {obj%type} C%category / : rename.
so the problem must be with Coq unfolding an [Object] where it shouldn't.  The definition of [Object] is [Object obj _ := obj].
Does anyone have any idea what's going on?
The code can be found at commit e117135 of https://bitbucket.org/JasonGross/catdb, the one-line change that I mentioned is in SpecializedCategory.v, and the failing file is UniversalProperties.v
The error is:
Toplevel input, characters 20-25:
Error: Illegal application (Type Error):
The term "InitialObject_Object" of type
 "forall (obj : Type) (C : SpecializedCategory obj), InitialObject C -> C"
cannot be applied to the terms
 "CommaCategory_Object (SliceCategory_Functor C X0) U" : "Type"
 "Build_SpecializedCategory (CommaCategory_Morphism (T:=U))
    (CommaCategory_Identity (T:=U)) (CommaCategory_Compose (T:=U))
    (CommaCategory_subproof (T:=U)) (CommaCategory_subproof0 (T:=U))
    (CommaCategory_subproof1 (T:=U))"
   : "SpecializedCategory
        (CommaCategory_Object (SliceCategory_Functor C X0) U)"
 "M" : "InitialMorphism"
The 3rd term has type "InitialMorphism" which should be coercible to
 "InitialObject
    (Build_SpecializedCategory (CommaCategory_Morphism (T:=U))
       (CommaCategory_subproof1 (T:=U)))".
Thanks,
Jason
  • [Coq-Club] Type error on [admit] after [simpl in *]?, Jason Gross, 03/31/2013
