- To: Matthieu Sozeau <mattam AT mattam.org>
- Cc: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Typeclass hints and rewrite
- Date: Sun, 31 Mar 2013 19:29:52 -0400
Thanks!
However, I have a goal where I can do
Create HintDb foobar discriminated.
Hint Rewrite @FIdentityOf : foobar.
Fail rewrite_db foobar. (* The command has indeed failed with message:
=> Error: Tactic failure:setoid rewrite failed: Nothing to rewrite. *)
setoid_rewrite @FIdentityOf. (* succeeds *)
The definition of [FIdentityOf] is
FIdentityOf =
fun (objC : Type) (C : ComputationalCategory objC)
(H : IsSpecializedCategory C) (objD : Type)
(D : ComputationalCategory objD) (H0 : IsSpecializedCategory D)
(F : ComputationalFunctor C D)
(IsSpecializedFunctor0 : IsSpecializedFunctor F) =>
let (_, FIdentityOf) := IsSpecializedFunctor0 in FIdentityOf
: forall (objC : Type) (C : ComputationalCategory objC)
(F : ComputationalFunctor C D),
IsSpecializedFunctor F ->
forall x : C, MorphismOf F (Identity x) = Identity (F x)
Arguments objC, C, H, objD, D, H0 are implicit
Argument IsSpecializedFunctor is implicit and maximally inserted
Argument scopes are [type_scope category_scope _ type_scope category_scope _
functor_scope _ object_scope]
The goal is
1 subgoals, subgoal 1 (ID 2696)
objC : Type
C : SpecializedCategory objC
objD : Type
D : SpecializedCategory objD
objE : Type
E : SpecializedCategory objE
G : SpecializedFunctor D E
F : SpecializedFunctor C D
x : C
MorphismOf G (Identity (F x)) = Identity (G (F x))
I can try to construct a small example reproducing the error, if you don't have any idea what's going on here.
Thanks,
Jason
On Fri, Mar 22, 2013 at 6:43 AM, Matthieu Sozeau <mattam AT mattam.org> wrote:
Hi Jason,
Le 22 mars 2013 à 05:32, Jason Gross <jasongross9 AT gmail.com> a écrit :
> Hint Rewrite @FIdentityOf using eauto with typeclass_instances : functor.
> Fail rewrite @FIdentityOf by auto with typeclass_instances. (* should not fail *)The problem is that, even before launching type class resolution, [rewrite] expects
> erewrite @FIdentityOf by auto with typeclass_instances.
the metavariables for H and H0 to be instantiated, that's why it fails. If instead it
used existential variables (like [setoid_rewrite FIdentityOf] does) it wouldn't fail.
There is an (undocumented) tactic [rewrite_db hintdb] which does setoid rewrite
using the rewrite hint database hintdb, but it doesn't take care of the side
condition tactic (yet). You could still use it like this:
Require Import Setoid.
Ltac rewrite_cat := rewrite_db functor; try typeclasses eauto.
And use rewrite_cat instead of your autorewrite.
-- Matthieu
- Re: [Coq-Club] Typeclass hints and rewrite, Jason Gross, 04/01/2013
