coq-club - Re: [Coq-Club] Sledgehammer for Coq?
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Sledgehammer for Coq?
  • Date: Wed, 03 Apr 2013 14:13:22 +0200
Thanks Arnaud for pointing this out. SMTCoq indeed provide tactics to
call SMT solvers. This is a recent work, so it currently requires the
goal to be a Boolean, not a proposition (we are currently improving
this). It is entirely safe and does not require classical logic.
There is no Coq tactic as powerful as Sledgehammer in Coq. To my
knowledge, the more powerful is what Claude presented, but it is indeed
unsafe.
Chantal.
Le 03/04/2013 10:24, Arnaud Spiwack a écrit :
> On interfacing external theorem provers with Coq in a safer manner, there
> is recent work like this one: with
> http://hal.inria.fr/docs/00/63/91/30/PDF/cpp11.pdf
> On 3 April 2013 10:16, Jonathan Heras
> <jonathan.heras AT unirioja.es>
> wrote:
>> On 03/04/13 08:58, Claude Marche wrote:
>>> Nevertheless, one should be aware of an important point: when the
>>> external prover answers that the goal is valid, then the Why3 tactic
>>> introduces an axiom in Coq to discharge the original goal. There is no Coq
>>> proof generated. This is an important issue if you want to restrict your
>>> trusted code base to the Coq kernel only. As far as I understand, this is
>>> not a issue in Isabelle/sledgehammer since Isabelle does not build proof
>>> terms internally (am I wrong ?)
>> In Isabelle, when the external prover answers that a goal is valid, it
>> also returns the lemmas which have been used for that proof. Then, those
>> lemmas are given as input to a program called Metis that tries to reproduce
>> the proof in Isabelle. In some cases, Metis cannot generate the proof even
>> if external prover says that a goal is valid; in those cases, the goal is
>> not admitted and in this way you always work with trusted code.
>> Cheers,
>> Jonathan
