coq-club - Re: [Coq-Club] Inductive definition problem
  • To: Coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Inductive definition problem
  • Date: Fri, 5 Apr 2013 15:06:29 +0900
Good evening,
The problem is that the deduction system you defined is wrong, at least IntroPar.
The rule you want is
[P1,P2]  |- c
---------------------introPar
[P1//P2] |- c
but, the rule you wrote is
[P1//P2] |- c
[P1,P2]  |- c
So, you should write IntroPar as
 |introPar : forall (p: list process) (q r : process) (c:constraint),
            Deduction ([q,r]++p) c -> Deduction ([q//r]++p) c.
In this kind of descriptions, a left side of an arrow (->) means "an assumption of the rule" and
a right side means "a result derived with the rule".
I hope this will help you.
Sosuke Moriguchi.
2013/4/5 mauricio cano <mcano.programas AT gmail.com>
Good night to everyone, i'm trying to implement a simple deduction system in coq, i have the following:
(*Requirements*)
Require Export List.
Require Export Permutation.
(*Global notation for lists*)
Notation "[]" := nil.
Notation "[ x , .. , y ]" := (x :: .. (y :: nil) ..) : list_scope.
(*Global definitions and more notation definitions*)
(*Tokens*)
Variable token:Set.
(*Definition of constraints*)
Inductive constraint : Type :=
 basic : token->constraint.
(*Definition of processes*) (*x : cartesian product*)
Inductive process : Type :=
  tell : constraint -> process (*tell : C |-> P*)
 |parallel : process -> process -> process (*parallel: PxP |-> P*)
 |ask : constraint -> process ->process. (*ask: cxP |-> P*)
(*Operations Notations (Syntactic Sugar!!)*)
Notation "tell( c )" := (tell c) (at level 30, right associativity).
Notation "p // q" := (parallel p q) (at level 30 , right associativity).
Notation "( 'ask' c 'then' p )" := (ask c p) (at level 30, right associativity).
Inductive Deduction : list process -> constraint -> Prop :=
  strPerm : forall (p q : list process) (c : constraint),
             Permutation p q -> Deduction p c -> Deduction q c
 |introTell : forall (p : list process) (c : constraint),
              Deduction ([tell(c)]++p) c
            Deduction ([q//r]++p) c -> Deduction ([q,r]++p) c.
 (* Definition of some tokens to work with *)
 Hypothesis t1 t2  t3: token.
 Definition c1:= (basic t1).
  Definition c2:= (basic t2).
  Definition c3:= (basic t3).
 (* Definition of a ccp process *)
 Definition P1:process := tell c1.
 Definition P2:process := tell c2.
 Definition P3: process:= (ask c1 then tell (c2)) // tell (c1).
  (* Some Theorems *)
  Theorem Th1: Deduction [P1 // P2]  c1.
   apply introPar with (p:=[P1 // P2]) (q:=P1) (r:=P2) (c:=c1). (The problem is here)
When i do the apply introPar i got the following error:
Error: Impossible to unify "Deduction ([P1, P2] ++ [P1 // P2]) c1" with
 "Deduction [P1 // P2] c1"
I pretty much know the problem is within the definition of Deduction, however, i'm pretty much new with types,functional languages and coq, so i was wondering if someone could point out what am i doing wrong and how to correct it.
what i want is that the proof ask me to prove that with [P1,P2] (given [P1 // P2]) i can prove c1 something like:
[P1,P2]  |- c
[P1//P2] |- c
Thank You,
Mauricio Alejandro Cano
Pontificia Universidad Javeriana
Facultad de Ingeniería
Ingeniería de Sistemas y Computación
