- From: Pierre Letouzey <pierre.letouzey AT inria.fr>
- To: coq-club club <coq-club AT inria.fr>
- Subject: [Coq-Club] Coq 8.4pl2
- Date: Fri, 5 Apr 2013 13:06:29 +0200 (CEST)
Dear coq-clubists,
8, 4, 2, Ready, Go ! After this binary countdown, I'm glad to announce
the availability of Coq 8.4, 2nd revision. Sources and Windows packages
are already on coq.inria.fr. MacOS packages are still underway (see [1]).
As usual, a fair amount of bugs have been solved since the last release,
but not all alas :-(, see CHANGES below or the bugzilla summary [2].
We'd like to thank all contributors and bug submitters. Among them,
I would like to personally thank Andrew Appel for his help during
the resolution of a nasty issue with the interrupt button of Coqide
for Windows (bug #2869).
Enjoy!
Pierre Letouzey, for the Coq Dev Team
[1] https://sympa.inria.fr/sympa/arc/coq-club/2013-01/msg00081.html
[2] Bugs resolved since last release (all versions, not only 8.4):
https://coq.inria.fr/bugs/buglist.cgi?list_id=769&chfieldto=Now&query_format=advanced&chfield=bug_status&chfieldfrom=2012-12-25&chfieldvalue=RESOLVED&bug_status=RESOLVED
Changes from V8.4pl1 to V8.4pl2
Bug fixes
- Solved bugs :
#2466 #2629 #2668 #2750 #2839 #2869 #2954 #2955 #2959 #2962 #2966 #2967
#2969 #2970 #2975 #2976 #2977 #2978 #2981 #2983 #2995 #3000 #3004 #3008
- Partially fixed bugs : #2830 #2949
- Coqtop should now react more reliably when receiving interrupt signals:
all the "try...with" constructs have been protected against undue
handling of the Sys.Break exception.
Coqide
- The Windows-specific code handling the interrupt button of Coqide
had to be reworked (cf. bug #2869). Now, in Win32 this button does
not target a specific coqtop client, but instead sends a Ctrl-C to
any process sharing its console with Coqide. To avoid awkward
effects, it is recommended to launch Coqide via its icon, its menu,
or in a dedicated console window.
Extraction
- The option Extraction AccessOpaque is now set by default,
restoring compatibility of older versions of Coq (cf bug #2952).
- [Coq-Club] Coq 8.4pl2, Pierre Letouzey, 04/05/2013
- Re: [Coq-Club] Coq 8.4pl2, Perry E. Metzger, 04/06/2013
