- To: Kenneth Roe <kendroe AT hotmail.com>
- Cc: Coq-Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Performance of simpl
- Date: Fri, 5 Apr 2013 10:35:00 -0400
Kenneth,
Defining z as (fact 10) does not actually evaluates (fact 10). If you want to
define z as the value of (fact 10), not the expression itself. You could do
this:
Definition z := Eval simpl in fact 10.
Or you could just print the value by running:
Of couse, there is an alternative definition that is observationally equal to
your "fact" function and run faster by caching the immediate previous value.
-- Duckki
On Friday, April 5, 2013 at 10:21 AM, Kenneth Roe wrote:
> Consider the following Coq declarations:
> Fixpoint fact (x : nat) := match x with
> | 0 => 1
> | (S y) => (S y) * (fact y)
> end.
> Definition z := fact 10.
> Theorem q: (fact 10)=10*(fact 9).
> Proof.
> simpl.
> The definition of "z" happens very quickly. However, the "simpl" at the
> very end takes a long time. And in fact generates a "Stack overflow" error.
> However, the only meaningful operation of simpl is to do an evaluation of
> the "fact" function. Is there an alternative to using "simpl" that is
> faster? What else can I do to speed up performance?
> - Ken
- [Coq-Club] Performance of simpl, Kenneth Roe, 04/05/2013
- Re: [Coq-Club] Performance of simpl, Adam Chlipala, 04/05/2013
- Re: [Coq-Club] Performance of simpl, Duckki Oe, 04/05/2013
- RE: [Coq-Club] Performance of simpl, Kenneth Roe, 04/05/2013
- Re: [Coq-Club] Performance of simpl, Jonas Oberhauser, 04/05/2013
- Re: [Coq-Club] Performance of simpl, Gregory Malecha, 04/05/2013
- RE: [Coq-Club] Performance of simpl, Kenneth Roe, 04/06/2013
- Re: [Coq-Club] Performance of simpl, Arnaud Spiwack, 04/06/2013
- Re: [Coq-Club] Performance of simpl, Thomas Braibant, 04/06/2013
