- From: Robbert Krebbers <mailinglists AT robbertkrebbers.nl>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Question about decidability of relations and proof irrelevance
- Date: Sun, 07 Apr 2013 12:17:53 +0200
On 04/07/2013 06:56 AM, Chris Dams wrote:
This kind of proof is in
generally possible for the cases you describe but it is kind of tedious.
There may be a more efficient way.
For such proofs, I use dependent equality (eq_dec) to simulate dependent pattern matching. In case equality of the indexes is decidable, eq_dec coincides with Leibniz equality for equal indexes.
This way you can do the proof in a more structured and less tedious way. It extends straightforwardly to most other inductive types.
Require Import Eqdep Eqdep_dec Omega Utf8.
Lemma nat_le_pi: ∀ (x y : nat) (p q : x < y), p = q.
Proof.
assert (∀ x y (p : x ≤ y) y' (q : x ≤ y'),
y = y' → eq_dep nat (le x) y p y' q) as aux.
{ fix 3. intros x ? [|y p] ? [|y' q].
* easy.
* clear nat_le_pi. omega.
* injection 1. intros Hy. now case (nat_le_pi x y p y' q Hy). }
intros x y p q. now apply (eq_dep_eq_dec eq_nat_dec), aux.
Qed.
- [Coq-Club] Question about decidability of relations and proof irrelevance, Jason Gross, 04/07/2013
- Re: [Coq-Club] Question about decidability of relations and proof irrelevance, Chris Dams, 04/07/2013
- Re: [Coq-Club] Question about decidability of relations and proof irrelevance, Robbert Krebbers, 04/07/2013
- Re: [Coq-Club] Question about decidability of relations and proof irrelevance, AUGER Cédric, 04/07/2013
- Re: [Coq-Club] Question about decidability of relations and proof irrelevance, Jason Gross, 04/07/2013
