- From: Sylvain Le Gall <sylvain+ocaml AT le-gall.net>
- To: Thomas Gazagnaire <thomas AT ocamlpro.com>
- Cc: François Bobot <francois.bobot AT cea.fr>, platform <platform AT lists.ocaml.org>, coq-club AT inria.fr, Thomas Refis <thomas.refis AT gmail.com>, Stefan Monnier <monnier AT iro.umontreal.ca>
- Subject: Re: [ocaml-platform] [Coq-Club] Coq opam package
- Date: Thu, 11 Apr 2013 16:11:14 +0200
2013/4/11 Thomas Gazagnaire
<thomas AT ocamlpro.com>:
>>>> The fact that you don't have a choice when installing a package to
>>>> update all the package that may use it or not, is imho really
>>>> frustrating. I have indeed had to recompile coq a few times as well,
>>>> and the experience gets more annoying every time.
>>> The solution for coq is to declare `labgtk` as an optional build-time
>>> dependency (eg. simply remove it from the list of optional link-time
>>> dependency, but let the right option in the configure invocation).
>> Interesting, it is quite simple.
>> But is it right that if you do that, when there is an important fix of
>> lablgtk you will have to explicitly run "opam reinstall coq" and all the
>> coq stdlib will be recompiled?
>> If it's true it is a nice and simple halfway solution.
> If lablgtk does not appear in the list of dependencies (and optional
> dependencies), coq will never be recompiled automatically when you upgrade
> lablgtk. And if you do "opam reinstall coq" OPAM will indeed recompile the
> whole package.
> Tracking dependencies at a finer grain that the package level requires
> build system hooks that OPAM doesn't have (yet?).
Isn't it possible to keep the compiled source tree (i.e. just what you
got before make install) and restart with a "make all". If it fails
and you know you try to resume from the middle, just start again with
"make clean; configure && make all".
If the build system supports detecting changes in external libraries,
this should be fine and you'll be able to incrementally recompile coq
-- if not, you fallback to the default mode. In other words, you move
the problem to the build system without any hooks. I am pretty sure
this is not supported by ocamlbuild, but it can be good incentive to
create something that works this way.
Cheers
Sylvain
- Re: [Coq-Club] Coq opam package, (continued)
- Re: [Coq-Club] Coq opam package, Stefan Monnier, 04/10/2013
- Re: [ocaml-platform] [Coq-Club] Coq opam package, Thomas Refis, 04/10/2013
- Re: [ocaml-platform] [Coq-Club] Coq opam package, Wojciech Meyer, 04/10/2013
- Re: [ocaml-platform] [Coq-Club] Coq opam package, Gregory Malecha, 04/10/2013
- Re: [ocaml-platform] [Coq-Club] Coq opam package, Anil Madhavapeddy, 04/10/2013
- Re: [ocaml-platform] [Coq-Club] Coq opam package, Wojciech Meyer, 04/11/2013
- Re: [ocaml-platform] [Coq-Club] Coq opam package, François Bobot, 04/17/2013
- Re: [ocaml-platform] [Coq-Club] Coq opam package, Thomas Gazagnaire, 04/11/2013
- Re: [ocaml-platform] [Coq-Club] Coq opam package, François Bobot, 04/11/2013
- Re: [ocaml-platform] [Coq-Club] Coq opam package, Sylvain Le Gall, 04/11/2013
- Re: [Coq-Club] Coq opam package, AUGER Cédric, 04/10/2013
