- To: coq-club AT inria.fr
- Subject: [Coq-Club] Proof of array bounds
- Date: Mon, 29 Apr 2013 11:57:56 +0200 (CEST)
- Importance: Normal
Hi All,
I have the following original Coq goal.
1 subgoal
______________________________________(1/1)
forall (r : Z) (rho : map Z Z) (rho1 : Z),
match to_abstract_stack (mk_stack_rep rho1 (mk_array r rho)) with
| Create => True
| Push _ _ => False
end /\ invariant_stack (mk_stack_rep rho1 (mk_array r rho)) ->
-2147483648 <= rho1 - 1 <= 2147483647
which translates to the following after the command
intros r rho rho1 r1 (h1,h2).
1 subgoal
r : Z
rho : map Z Z
rho1 : Z
r1 := mk_stack_rep rho1 (mk_array r rho) : stack_rep
h1 : ~
match to_abstract_stack r1 with
| Create => True
| Push _ _ => False
end
h2 : invariant_stack r1
- (2147483648) <= rho1 - 1 <= 2147483647
rho1 is the index bound for the array and invariant_stack
is defined as.
Definition invariant_stack(r:stack_rep): Prop := (0%Z <= (size r))%Z /\
((size r) <= (length (data r)))%Z.
which gives the bound on the size of the array.
Do someone have any clue, how to carry the proof regarding
the array index bound in Coq?
Thanks.
regards,
tk
- [Coq-Club] Proof of array bounds, mtkhan, 04/29/2013
