- To: coq-club AT inria.fr
- Subject: [Coq-Club] Reduction of a term (with a def in proof mode)
- Date: Wed, 1 May 2013 20:40:32 +0200 (CEST)
Hi,
I am facing a problem with Coq that I've already faced, but I'm not able to
remember exactly what was the previous solution (or maybe the problem here is
a bit different).
I have defined some functions, and some of them are defined in the proof mode.
Specially, I have a function "bigFun" which is defined in the proof mode.
When I apply bigFun to some arguments, I'm expecting to have a readable
result, which is of type nat, so I expect simply a natural number.
Instead, I get a horrible unfolding of my term, but without any reduction.
The first thing I've check was of course if I always finish my definition by
"Definef" instead of "Qed" for the functions I have defined in the proof mode.
But that's fine...
So I've try to enunciate a lemma, which states the equality with the value I'm
expecting :
Lemma isOne : bigFun someArgs = 1.
Proof.
"reflexivity" doesn't works : the system says that it's impossible to unify
(bigFun someArgs) and 1. But it doesn't try to reduce the left side of "=".
I would of course prefer for exemple the error "impossible to unify 3 and 1",
which would mean that my function doesn't behave like expected.
I've also try "simpl", "red", but nothing enables me to obtain just the
"final" result : a natural number.
If you have any clue it would be very nice.
Kind regards.
- [Coq-Club] Reduction of a term (with a def in proof mode), rooster, 05/01/2013
- Re: [Coq-Club] Reduction of a term (with a def in proof mode), Pierre Casteran, 05/01/2013
- Re: [Coq-Club] Reduction of a term (with a def in proof mode), Maxime Dénès, 05/01/2013
- FW: [Coq-Club] Reduction of a term (with a def in proof mode), Franck Tidus, 05/04/2013
- Re: FW: [Coq-Club] Reduction of a term (with a def in proof mode), Thomas Braibant, 05/04/2013
