- To: "Adam Chlipala" <adamc AT csail.mit.edu>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Proof of structural equality
- Date: Tue, 7 May 2013 08:49:21 +0200 (CEST)
- Importance: Normal
Hi,
Thanks Adam again; yes, the later tactics worked. I am still wondering
what is the general proof strategy in Coq for such structural
equality?
For example now, in the following
1 subgoal
e : int
rho : int
rho1 : Map.map int int
rho2 : int
r := mk_stack_rep rho2 (mk_array rho rho1) : stack_rep
h1 : 0 <= rho
h2 : invariant_stack r
h3 : rho2 = rho -> 2 * rho + 1 < 2147483647
h4 : rho2 <> rho
h5 : 0 <= rho2
h6 : rho2 < rho
o : Map.map int int
h7 : 0 <= rho
h8 : o = Map.set rho1 rho2 e
h9 : - (2147483648) <= rho2 + 1
h10 : rho2 + 1 <= 2147483647
rho3 : int
h11 : rho3 = rho2 + 1
h12 : 0 <= rho
s : stack
z : int
H : to_abstract_stack (mk_stack_rep rho3 (mk_array rho o)) = Push s z
______________________________________(1/1)
s = to_abstract_stack r /\ z = e
I want to prove
1) s = to_abstract_stack r
2) z = e
How can I really proceed without induction on z or e in the
second case. Also any clue or help regarding case 1, where
stack is inductively defined as
Inductive stack :=
| Create : stack
| Push : stack -> Z -> stack.
Thanks.
regards,
taimoor
> On 05/06/2013 11:26 AM,
> mtkhan AT risc.uni-linz.ac.at
> wrote:
>> H0 : s = to_abstract_stack r /\ z = e
>> Push s z = Push (to_abstract_stack r) e
>> my question here, how to prove structural induction reasonably
>> in a well-manner in Coq.
> Perhaps there is some aspect of your problem that isn't expressed
> adequately by the above goal, but it looks to me like the goal can be
> proved with
> congruence
> or maybe
> intuition congruence
> if the former isn't smart enough. It follows by basic properties of
> equality, with no induction required.
- [Coq-Club] Proof of structural equality, mtkhan, 05/06/2013
- Re: [Coq-Club] Proof of structural equality, Adam Chlipala, 05/06/2013
- Re: [Coq-Club] Proof of structural equality, mtkhan, 05/07/2013
- Re: [Coq-Club] Proof of structural equality, Cedric Auger, 05/07/2013
- Re: [Coq-Club] Proof of structural equality, Adam Chlipala, 05/07/2013
