- From: Frederic Blanqui <frederic.blanqui AT inria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Inductive data types modulo equations in Coq
- Date: Tue, 07 May 2013 17:30:01 +0800
Hello. For references, there is also Pierre Courtieu's 2001 PhD in French: " Représentation de structures non libres en théorie des types" and his CSL'01 paper "Normalized types". But I don't know if it has been implemented. Best regards, Frederic. Le 07/05/2013 17:08, Arnaud Spiwack a
écrit :
On 05/06/2013 11:22 AM, Arnaud Spiwack
wrote:
Is there a good reference using this technique orThe normal method in Coq is indeed to define a setoid equality on lists. should I cite this as folklore? I don't think there is anything specific. Setoids as a way to do mathematics go back to Bishop's 1967 book Foundations of constructive analysis (although he didn't call them that way). It is a common way conduct mathematics in Coq. Or in a constructive setting in general. The current implementation of so-called setoid rewriting in Coq is due to Matthieu Sozeau (see A New Look at Generalized Rewriting in Type Theory). An alternative method of defining quotient has been played with in the recent month within the framework of homotopy type theory: higher inductive type (in which case it would work nicely with Coq's native equality rather than a setoid equality). It is not available in Coq yet (though I understand there is a prototype out there). * The identity type of HTT would then be a new proof-relevant propositional equality type in Coq, while the definitional equality stays the same? * This new equality will not be an automated Leibniz equality and people want to write out substitution "transport" explicitly (because of proof-relevance)? * If this is true, the identification of constructor terms will only be possible by manual application of the equality proofs? Is that not worse than using rewriting with a setoid equality? The benefit over using setoid equality will therefore only be that functions over the higher inductive type are automatically invariant under homotopic transport? Well, you shouldn't focus on the proof relevance thing. It's not relevant to this particular application. All in all, it would be pretty much like the setoid situation, but internalised within the native equality. Resulting in a lot fewer proofs obligations to be discharged by the user, and much smaller proof terms. Alternatively I would like to name the (future) implementors of this Coq extension and not just point to the homotopy blog.
I forgot another approach to quotient, a bit like what Moca
does, but without the automation. The idea is that if you have
a notion of canonical form, and a test for canonicity the
(dependent) type { x:A | canonical x = true } happens to be a
quotient (in fact a retraction) of A for the equality of Coq,
without any proof obligations to prove ever. It's been perused
in Cyril Cohen's PhD.
That sounds more like in the spirit of what you are trying to
do.
I'm not aware of any work that would try to change definitional equality to achieve this sort of quotients. |
- [Coq-Club] Inductive data types modulo equations in Coq, Andreas Schropp, 05/05/2013
- Re: [Coq-Club] Inductive data types modulo equations in Coq, Arnaud Spiwack, 05/06/2013
- Re: [Coq-Club] Inductive data types modulo equations in Coq, Andreas Schropp, 05/06/2013
- Re: [Coq-Club] Inductive data types modulo equations in Coq, Arnaud Spiwack, 05/07/2013
- Re: [Coq-Club] Inductive data types modulo equations in Coq, Frederic Blanqui, 05/07/2013
- Re: [Coq-Club] Inductive data types modulo equations in Coq, Pierre Courtieu, 05/15/2013
- Re: [Coq-Club] Inductive data types modulo equations in Coq, Bas Spitters, 05/14/2013
- Re: [Coq-Club] Inductive data types modulo equations in Coq, Frederic Blanqui, 05/06/2013
