coq-club - Re: [Coq-Club] Eapply Breaks
  • To: Coq-club <coq-club AT inria.fr>
  • Cc: bhandalc AT tcd.ie
  • Subject: Re: [Coq-Club] Eapply Breaks
  • Date: Sat, 11 May 2013 03:46:04 +0900
Hi Colm,
I have got the same question, but this is just usual, and not a bug.
"eapply" just waits instantiation of some variables, and instantiated terms
MUST be describable in the context of application of "eapply".
Otherwise, we can prove the following theorem.
Goal (exists a : A, P a) -> { x : A | P a }.
when we use following variables.
Variables (A : Type) (P : A->Prop).
This shows that, we can make a program (which is predicative)
from a predicate (which is impredicative).
Best regards,
Sosuke Moriguchi.
2013/5/11 <bhandalc AT tcd.ie>
Hi  people,
Just noticed some unusual behaviour of eapply. It's not a big deal, very easy
to work around, but just thought I'd flag it. I'm using Coq version 8.3pl5.
Here is the code:
(*Just a simple Lemma for use in the test lemma*)
Lemma simple : forall (x y : nat),
  x < y -> y <> 0. intros. destruct y.
  inversion H. unfold not. intro.
  inversion H0. Qed.
(*This works OK*)
Lemma testGood : forall y : nat,
  (exists x : nat, x < y) -> y <> 0.
  intros. inversion H. eapply simple.
  apply H0. Qed.
(*This breaks with the error message: Error: Impossible to unify "?25" with
"x".*)
Lemma testBug : forall y : nat,
  intros. eapply simple. inversion H.
  apply H0.
It seems as though eapply doesn't like when you instantiate existentials in a
hypothesis after the application- they must have existsed beforehand. The
workaround is simple: Just instantiate before eapply. But I believe the
behaviour is of interest nonetheless.
All the best,
Colm
