Re: [Coq-Club] Explanation of Application of lemmas whose beta-iota normal form contains metavariables deep inside the term is not supported
- To: Jason Gross <jasongross9 AT gmail.com>
- Cc: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Explanation of Application of lemmas whose beta-iota normal form contains metavariables deep inside the term is not supported
- Date: Thu, 16 May 2013 08:08:26 +0200
Le Wed, 15 May 2013 22:20:27 -0400,
Jason Gross
a écrit :
> Hi,
> Can someone explain to me the error message in the following code,
> and why the bottom snippet causes it, but the top snipped does not?
> Record Foo := { foo : forall A : Set, True }.
> Goal Foo.
> pose (fun pf : Set -> True => @Build_Foo (fun A => pf A)) as H.
> apply H.
> Abort.
> Goal Foo.
> apply (fun pf : Set -> True => @Build_Foo (fun A => pf A)).
> (* Toplevel input, characters 22-72:
> Error: in : Application of lemmas whose beta-iota normal form contains
> metavariables deep inside the term is not supported; try "refine"
> instead. *)
> Thanks,
> Jason
I am not sure of this, but in the second case,
"apply (fun pf : Set -> True => @Build_Foo (fun A => pf A))."
the returned type is not Foo, so it probably tries to use internally
something like:
"apply ((fun pf : Set -> True => @Build_Foo (fun A => pf A)) _).",
performs simplification to have:
"apply (@Build_Foo (fun A => _ A)).",
which cannot be solved, due to existentials.
eapply does not give better result though.
In the pose (H := …) version (it is the same as pose (…) as H.), you
introduce a definition, and this cannot be reduced, so
"apply H." does not work, but "apply (H _)." does since H is not
unfolded, and the form where existentials are on top of the term seem
to be managed by apply, unlike those which are deep (like the error
said).
Let H := fun pf : Set -> True => @Build_Foo (fun A => pf A).
Eval simpl in (H _).
Eval simpl in ((fun pf : Set -> True => @Build_Foo (fun A => pf A)) _).
I think that is the reason, but I am all but certain on it.
- [Coq-Club] Explanation of Application of lemmas whose beta-iota normal form contains metavariables deep inside the term is not supported, Jason Gross, 05/16/2013
- Re: [Coq-Club] Explanation of Application of lemmas whose beta-iota normal form contains metavariables deep inside the term is not supported, AUGER Cédric, 05/16/2013
