- To: Adam Chlipala <adamc AT csail.mit.edu>
- Cc: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Search vs SearchAbout
- Date: Sat, 18 May 2013 11:11:43 -0400
Adam, your explanation works for trunk, where [Search] gives me things of type [Z -> Z -> bool], and [SearchAbout] gives me things of type, e.g., [Morphisms.Proper (Morphisms.respectful eq Z.eqf) Z.testbit]. But in 8.4 pl2, [Search] gives [Zneq_bool] and [Zeq_bool], and not [Z.leb], even though they are all of type [Z -> Z -> bool]. I thought it might have something to do with module scoping, but [Import Z.] does not change the result. Perhaps this is a bug in 8.4?
-Jason
On Sat, May 18, 2013 at 9:15 AM, Adam Chlipala <adamc AT csail.mit.edu> wrote:
On 05/17/2013 09:48 PM, Math Prover wrote:These explanations seem to give the complete story on the difference between the commands. Perhaps the issue is that you aren't familiar with the terminology "head position"? The upshot in this case seems to be that [Search] only considers types that match your query with extra [forall]s added in front, whereas [SearchAbout] applies a looser rule.
Here is my question: How does Search and SearchAbout differ in practice?
The manual states:
It is often difficult to remember the names of all lemmas and definitions available in the current context, especially if large libraries have been loaded. A convenient SearchAbout command is available to lookup all known facts concerning a given predicate. For instance, if you want to know all the known lemmas about the less or equal relation, just ask:
and
Another command Search displays only lemmas where the searched predicate appears at the head position in the conclusion.
- [Coq-Club] Search vs SearchAbout, Math Prover, 05/18/2013
- Re: [Coq-Club] Search vs SearchAbout, Adam Chlipala, 05/18/2013
- Re: [Coq-Club] Search vs SearchAbout, Jason Gross, 05/18/2013
- Re: [Coq-Club] Search vs SearchAbout, Pierre-Marie Pédrot, 05/18/2013
