coq-club - Re: [Coq-Club] Hint Record Constructors? Macros in Coq ?
  • To: Math Prover <mathprover AT gmail.com>
  • Cc: "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Hint Record Constructors? Macros in Coq ?
  • Date: Sun, 19 May 2013 07:14:01 +0200
`apply f_equal3' does what you want
On Sun, May 19, 2013 at 4:02 AM, Math Prover
wrote:
> Hi,
> I have a rather simplistic question (and will not take offense at an
> response of the form "read section X.Y.Z of the manual").
> I want to know if there is a way to automatically generate lemmas of the
> form simp_lem.
> The way this happens in my work flow is:
> ### Problem
> (1) I define some Record class Foo.
> (2) In writing a proof, I have something like:
> Hypothesis: ...
> Goal: Build_Foo a1 a2 a3 = Build_Foo b1 b2 b3
> (3) Now, I want to using one command, change my state to something with 3
> goals:
> Hypothesis: ...
> Main Goal: a1 = b1
> Next Goal: a2 = b2
> Next Goal: a3 = b3
> ### Current Solution
> The only way I currently know how to solve this problem is by manually
> defining "simp_lem" and typing in "apply simp_lem."
> ### Desired Solution
> I would be able to type in something like:
> apply Record_Constructor_Break(Foo)
> and have it auto generate the lemma and apply it.
> ### Relation to Macros
> I like lisp macros. One possible way to do this would be if Coq had
> something like Macros; and if so, I'd be able to write
> Record_Constructor_Break once, and it'd work for all Records by generating
> the proof on the fly by examining the structure of the Records.
> ### Actual Question:
> (1) What is the best way to do the above?
> (2) Does Coq have anything like Macros?
> (3) If Coq does not have Macros, for the above problem, can I somehow still
> build it using Program/Refine?
> Thanks!
> ==== Code ====
> Require Import CpdtTactics.
> Inductive Foo1 :=
> | Foo1_1 : nat -> Foo1
> | Foo1_2 : nat -> nat -> Foo1
> | Foo1_3 : nat -> nat -> nat -> Foo1 .
> Inductive Foo2 :=
> | Foo2_1 : nat -> Foo2
> | Foo2_2 : nat -> Foo2
> | Foo2_3 : nat -> Foo2.
> Inductive Foo3 := Foo3_1 | Foo3_2 | Foo3_3.
> Record Foo : Set := {
> foo1 : Foo1;
> foo2 : Foo2;
> foo3 : Foo3 }.
> Lemma simp_lem:
> forall f1 f2 f3 g1 g2 g3,
> f1 = g1 ->
> f2 = g2 ->
> f3 = g3 ->
> Build_Foo f1 f2 f3 = Build_Foo g1 g2 g3.
> crush. Qed.
> (* now, in other parts, of my proof, I can use "apply simp_lem" *)
Give me liberty or give me cash!
