coq-club - Re: [Coq-Club] Export Without Notation
  • To: Pierre Boutillier <pierre.boutillier AT pps.univ-paris-diderot.fr>
  • Cc: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Export Without Notation
  • Date: Fri, 17 May 2013 12:02:40 -0400
> Anyway, I see an annoying point : Using notations in the module where you
> define stuff you
> make notations for asks for defining notations twice. As you can see,
> notations about
> vectors are defined twice. Once locally in order to be allowed to use []
> and :: in
> VectorDef module but not disturb other modules and once in the correct
> module to make
> them publicly available.
This is true if you want to define the notation inline with an
Inductive, but in your case, I think you could define the notation in
parts, like this:
(* ...defs... *)
Module Internal_ListNotations.
Notation "[]" := (nil _).
Notation "h :: t" := (cons _ h _ t) (at level 60, right associativity).
Import Internal_ListNotations.
(* ...more defs & lemmas... *)
Module VectorNotations.
Export Internal_ListNotations.
Notation " [ x ] " := (x :: []) : vector_scope.
Notation " [ x ; .. ; y ] " := (cons _ x _ .. (cons _ y _ (nil _))
..) : vector_scope.
Notation "v [@ p ]" := (nth v p) (at level 1, format "v [@ p ]") :
vector_scope.
Open Scope vector_scope.
End VectorNotations.
However, I'm not sure if this approach is ultimately less ugly because
of the module messiness...
-cj
