- To: Gregory Malecha <gmalecha AT eecs.harvard.edu>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Type Class Resolution
- Date: Thu, 23 May 2013 23:24:07 -0400
I know this is from quite a while ago, and I don't know if you've since solved it, but I was clearing out my inbox, and figured I'd take a crack at it.
If you move [Existing Class SetI_P.] to above your [Context] line, it works fine. It also works fine if you add [Existing Instance p.] after [Existing Class SetI_P.]. I suspect that Coq only checks known instances, rather than the context.
On Thu, Nov 15, 2012 at 5:14 PM, Gregory Malecha <gmalecha AT eecs.harvard.edu> wrote:
Class SetI t :={ SetI_P : Type -> Type; sinsert_with : forall {E} {p:SetI_P E}, (E -> E -> E) -> E -> t E -> t E}.
Definition const {A B} : A -> B -> A := fun x _ => x.Section SetI.Context {t} {E:Type} {S:SetI t} {p:SetI_P (t:=t) (SetI:=S) E}.(* Typeclasses Transparent SetI_P. *)Set Printing Implicit.Typeclasses eauto := debug dfs.Existing Class SetI_P.(* Hint Extern 5 (@SetI_P _ _ _) => eassumption : typeclass_instances. *)Definition sinsertl : E -> t E -> t E := sinsert_with const.End SetI.
- Re: [Coq-Club] Type Class Resolution, Jason Gross, 05/24/2013
