- To: "Harley D. Eades III" <harley.eades AT gmail.com>
- Cc: Kenneth Adam Miller <kennethadammiller AT gmail.com>, Coq-Club Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] CoC
- Date: Wed, 29 May 2013 11:55:19 -0400
>> [...] Also no universes, so it cannot be proven that
>> booleans true and false are different.
> Do you have a reference showing the latter point about universes?
The Independence of Peano's Fourth Axiom from Martin-Löf's Type Theory
without Universes. Journal of Symbolic Logic, 53(3), 1988.
This paper shows (Suc n) ~= n is unprovable without universes, for the
same reason as what I said. If you make the one (consistent)
assumption that true ~= false (Church booleans), you can the prove
distinctness of all constructors of all Church datatypes.
Randy
On Tue, May 28, 2013 at 11:47 PM, Harley D. Eades III
wrote:
> Hi, Randy.
> On May 28, 2013, at 2:33 PM, Randy Pollack
> <rpollack AT inf.ed.ac.uk>
> wrote:
>> If you want to know how the (pure) Calculus of Conctructions works,
>> read the Coquand/Huet paper in EUROCAL '85 (LNCS 203) and
>> Paulin-Mohring's paper in LICS 1986.
>> There are no inductive types, and definition by impredicative
>> intersection gives only "weak" iterators; so no constant time
>> predecessor function. Also no universes, so it cannot be proven that
> Thanks,
> .\ Harley
>> On the other hand some
>> non-strictly-positive types can be defined impredicatively, although
>> you can't do much with them.
>> Randy
>> On Tue, May 28, 2013 at 12:17 AM, Kenneth Adam Miller
>> wrote:
>>> My impression is that the Calculus of Constructions would be something
>>> incredibly valuable to know and be able to wield. Since it was born
>>> within the
>>> past few decades, I had surmised that it hadn't hit mainstream because the
>>> learning curve is incredibly high and because its so new; are these
>>> correct?
>>> Also, when reading the Coq'Art book, I find that there are a number of
>>> subtle
>>> and even explicit references to the CoC, and I want to be able to
>>> understand
>>> the CoC fundamentally in order to draw the most out of this book. I
>>> searched
>>> everywhere for the original publication that was cited in the book, but
>>> couldn't find it available on the open web. Would anybody know where a
>>> good
>>> set of materials might be, other than the Software Foundations or Coq'Art
>>> book, both of which I already have access to?
- [Coq-Club] CoC, Kenneth Adam Miller, 05/28/2013
- Re: [Coq-Club] CoC, Marco Servetto, 05/28/2013
- Re: [Coq-Club] CoC, Kristopher Micinski, 05/28/2013
- Re: [Coq-Club] CoC, Cody Roux, 05/28/2013
- Re: [Coq-Club] CoC, Richard Dapoigny, 05/28/2013
- Re: [Coq-Club] CoC, Randy Pollack, 05/28/2013
- Re: [Coq-Club] CoC, Harley D. Eades III, 05/29/2013
- Re: [Coq-Club] CoC, Randy Pollack, 05/29/2013
- Re: [Coq-Club] CoC, Kenneth Adam Miller, 05/30/2013
- Re: [Coq-Club] CoC, Jonas Oberhauser, 05/31/2013
- Re: [Coq-Club] CoC, Cody Roux, 05/31/2013
- Re: [Coq-Club] CoC, Kenneth Adam Miller, 05/31/2013
- Re: [Coq-Club] CoC, Arnaud Spiwack, 05/31/2013
- Re: [Coq-Club] CoC, Pierre-Marie Pédrot, 05/31/2013
- Re: [Coq-Club] CoC, Frédéric Blanqui, 05/31/2013
