- To: Gabriel Scherer <gabriel.scherer AT gmail.com>
- Cc: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] record value of "destruct" tactic
- Date: Fri, 31 May 2013 22:32:58 -0700
Exactly what I was looking for. Thanks!
On Fri, May 31, 2013 at 10:29 PM, Gabriel Scherer <gabriel.scherer AT gmail.com> wrote:
Since 8.4 you can use
destruct <expr> eqn:<naming intro pattern>
http://coq.inria.fr/distrib/current/refman/Reference-Manual010.html#hevea_tactic65
The previous (< 8.4) syntax was
destruct <expr> as ... _eqn
or
destruct <expr> as ... _eqn:<naming intro pattern>
This "eqn:" syntax also work for "remember" and "induction".
On Sat, Jun 1, 2013 at 4:57 AM, Math Prover <mathprover AT gmail.com> wrote:
> Hi!
> This is a minimal test case of a problem I'm running into.
> Often, when I do "destruct [big complicated _expression_]", I would like to
> have a hypothesis of the form:
> H: [big complicated _expression_] = value1
> The reason this shows up is that often I destruct _expression_, but then
> later, when I unfold another _expression_, I need access to the initial
> destructed _expression_. Thus, my question: is there a way to do something
> like "destruct expr; but also remember that expr = ... as a hypothesis"
> Thanks!
- [Coq-Club] record value of "destruct" tactic, Math Prover, 06/01/2013
- Re: [Coq-Club] record value of "destruct" tactic, Gabriel Scherer, 06/01/2013
- Re: [Coq-Club] record value of "destruct" tactic, Math Prover, 06/01/2013
- Re: [Coq-Club] record value of "destruct" tactic, AUGER Cédric, 06/03/2013
