- To: Math Prover <mathprover AT gmail.com>
- Cc: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Destructing a "nat" into 0, 1, 2, 3, ..., k-1 and ">= k"
- Date: Sat, 1 Jun 2013 12:30:08 +0100
Hi,
This is what I came up with. It's slower than the "magic" Ltac function
but you do get a nice "n <= k" assumption in the last case rather than
a huge series of S constructors.
Cheers,
gallais
Require Import Arith.
Section case_analysis_up_to.
Variable (P : nat -> Prop).
Fixpoint holds_up_to (n : nat) :=
match n with
| O => True
| S k => P k /\ holds_up_to k
end.
Lemma lookup : forall n, holds_up_to n ->
forall k, k < n -> P k.
Proof.
intros n ih k lt ; induction lt.
apply ih.
apply IHlt, ih.
Qed.
Lemma case_up_to : forall k,
holds_up_to k ->
(forall n, k <= n -> P n) ->
forall n, P n.
Proof.
intros k ih Pn n ; destruct (le_lt_dec k n) as [above | under].
apply Pn, above.
eapply lookup; eauto.
Qed.
End case_analysis_up_to.
Ltac case_up_to k := eapply case_up_to with k; [simpl; repeat split|].
On 1 June 2013 05:56, Math Prover
wrote:
> Hi,
> In my assumptions, I have something like this:
> n: nat
> ========== (1/1)
> Now, I want to tactic "magic", s.t. "magic n k" gives me the cases: n=0,
> n=1, ..., n=k-1, and n>=k.
> So, if I were to type "magic n k", I would get:
> n=0
> ========= (1/k+1)
> n=1
> ========= (2/k+1)
> n=k-1
> ======= (k/k+1)
> H: n>=k
> ========= (k+1/k+1)
> My question: is there anyway to do this with Ltac? In particular, although I
> see how to use match/try/repeat in ltac, I don't see how do I can do looping
> / testing of arguments? (i.e. how to embed "Z.leb n k" into my ltac).
> Thanks!
- [Coq-Club] Destructing a "nat" into 0, 1, 2, 3, ..., k-1 and ">= k", Math Prover, 06/01/2013
- [Coq-Club] Re: Destructing a "nat" into 0, 1, 2, 3, ..., k-1 and ">= k", Math Prover, 06/01/2013
- Re: [Coq-Club] Destructing a "nat" into 0, 1, 2, 3, ..., k-1 and ">= k", Yucheng Zhang, 06/01/2013
- Re: [Coq-Club] Destructing a "nat" into 0, 1, 2, 3, ..., k-1 and ">= k", Math Prover, 06/01/2013
- Re: [Coq-Club] Destructing a "nat" into 0, 1, 2, 3, ..., k-1 and ">= k", Pierre Courtieu, 06/03/2013
- Re: [Coq-Club] Destructing a "nat" into 0, 1, 2, 3, ..., k-1 and ">= k", Math Prover, 06/03/2013
- Re: [Coq-Club] Destructing a "nat" into 0, 1, 2, 3, ..., k-1 and ">= k", Yucheng Zhang, 06/03/2013
- Re: [Coq-Club] Destructing a "nat" into 0, 1, 2, 3, ..., k-1 and ">= k", gallais, 06/03/2013
- Re: [Coq-Club] Destructing a "nat" into 0, 1, 2, 3, ..., k-1 and ">= k", Vincent Demange, 06/03/2013
