coq-club - Re: [Coq-Club] Fwd: intros x [H1 | H1]
  • To: Valentin ROBERT <vrobert AT cs.ucsd.edu>
  • Cc: Marcus Ramos <mvmramos AT gmail.com>, "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Fwd: intros x [H1 | H1]
  • Date: Tue, 4 Jun 2013 23:11:33 +0200
Le Mon, 3 Jun 2013 10:28:52 -0700,
Valentin ROBERT
a écrit :
> Hello Marcus,
> This pattern is described here:
> http://coq.inria.fr/distrib/8.4/refman/Reference-Manual010.html#hevea_tactic35
> (the "a disjunction of lists of patterns" part is relevant)
> It basically allows you to destruct the introduced element as it is
> being introduced. Here the argument following x seems to be of a type
> with two constructors containing one element each (something like sum
> or sumbool). The syntax is similar to what you can use with the
> tactic destruct for instance.
> It should therefore leave you in a state with two subgoals, each one
> containing a hypothesis H1 accounting for the two possibilities.
> - Valentin
Yes, and there is also a pattern I often use with this feature:
Imagine you have a "P x" hypothesis and your goal is "x = y → P y".
x : X
H : P x
x = y → P y
The proof is trivial, here: "intros Heq; rewrite Heq; exact H." for
instance. But with the destruct feature of intro(s), you can do even
faster: "intros []; exact H."
I think lot of us will discourage you to use this feature. But I find
it often convenient.
Same for "False → P", here you can do "intros []." which is faster (at
least to write) than "discriminate." for instance, and without
wondering if "auto" can or cannot deal with it.
