coq-club - Re: [Coq-Club] Scope of definitions
  • From: "Terrell, Jeffrey" <jeffrey.terrell AT kcl.ac.uk>
  • To: Pierre Courtieu <pierre.courtieu AT gmail.com>
  • Cc: Adam Chlipala <adamc AT csail.mit.edu>, Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Scope of definitions
  • Date: Wed, 5 Jun 2013 18:20:14 +0000
  • Accept-language: en-GB, en-US
Thanks Pierre and Adam. I should have consulted the documentation but I was pressed for time. I think what confused me was the fact that Coq raises a warning if you use "Variable" at global scope, but it doesn't raise a warning if you use "Definition" at local scope. I presume that's because local scope is nested within global scope.
Regards,
Jeff.
On 5 Jun 2013, at 16:36, Pierre Courtieu wrote:
To be more explicit than Adam, if you want to "hide" things (that is: put them in their own namespace) you might want to consider modules instead of sections.
Best,
Pierre
2013/6/4 Adam Chlipala <adamc AT csail.mit.edu>
On 06/04/2013 03:28 AM, Terrell, Jeffrey wrote:
I was surprised to find that y is still in scope after the section is closed.
Definition x : nat := 1.
Print All.
Section P.
    Definition y : nat := 2.
    Print All.
End P.
Print All.
Do definitions (as opposed to declarations) always have global scope? If so, why?
Making definitions with global scope (or at least outside-the-section scope) is precisely the purpose of Coq sections.  Perhaps it's worth having look at the manual or another introduction to sections.
