- To: "Andrew W. Appel" <appel AT cs.princeton.edu>
- Cc: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Can Ltac choose a bound variable?
- Date: Wed, 12 Jun 2013 12:45:46 -0400
I have often found that [appcontext] is a useful tool to blow holes through the abstraction of Ltac:
Here's a slightly more general version of the same tactic:
-Jason
Goal forall T P, (exists old : T, P old) /\ True. intros T P. match goal with | [ |- ?A /\ True ] => match A with | appcontext G[P] => let G' := context G[fun x => P x /\ True] in assert G' end end.
Goal forall T P, (exists old : T, P old) /\ True. intros T P. match goal with | [ |- ?A /\ True ] => match A with | @ex ?T ?P => match A with | appcontext G[P] => let G' := context G[fun x => P x /\ True] in assert G' end end end.I suspect the reason for your troubles is that 'y' has two names, 'y' and 'old', and which name is used depends on where 'y' occurs in the _expression_. I'll leave it to someone more familiar with the coq source code to explain which OCaml methods correspond to which names, and where each gets used. (Or I might go source-diving myself, later.)
-Jason
On Tue, Jun 11, 2013 at 1:40 PM, Andrew W. Appel <appel AT cs.princeton.edu> wrote:
(* This little Coq development asks, "can an Ltac program choose the name of
a bound variable when building a lambda?"
If you know a way, please tell me. If you know it is not possible, tell me that too.
I don't subscribe to coq-club, so please cc me on any e-mail.
Sincerely, Andrew Appel.
Axiom ex_and: forall A (F: A -> Prop) Q, (ex F /\ Q) = (ex (fun x => F x /\ Q)).
Parameter P: nat -> Prop.
Goal (exists old, P old) /\ True.
rewrite ex_and.
(* PROBLEM: the goal is now, exists x : nat, P x /\ True
when I want it to be, exists old : nat, P old /\ True
Abort.
replace ((exists old : nat, P old) /\ True)
with (exists old : nat, P old /\ True)
by (symmetry; apply ex_and).
(* NOTE: the goal is now, exists old : nat, P old /\ True
This demonstrates that in some circumstances
the user CAN choose the name of the bound variable.
Abort.
match goal with |- (ex (fun y => _)) /\ _ =>
pose (y := False)
end.
(* The goal is now,
old := False : Prop
______________________________________(1/1)
(exists old0 : nat, P old0) /\ True
This demonstrates that the tactic system CAN
grab the name of a bound variable from a term.
Abort.
match goal with |- ex ?A /\ _ =>
match A with (fun y => _) =>
assert (ex (fun y => A y /\ True))
end
end.
(* The goal is now, exists y : nat, P y /\ True.
This demonstrates that the user cannot choose the "new"
bound variable y to match the name of the old one.
Abort.
let y' := fresh y in
assert (ex (fun y' => A y' /\ True))
end
end.
(* The goal is now, exists y' : nat, P y' /\ True.
This demonstrates that the [fresh] tactic is not useful here.
Abort.
(* CHALLENGE: write an Ltac that, for any name n,
rewrites a goal of the form
(exists n, P n) /\ True into (exists n, P n /\ True)
such that the bound variable [n] in the right-hand side
is the same as the name matched on the left-hand side.
- [Coq-Club] Can Ltac choose a bound variable?, Andrew W. Appel, 06/11/2013
- Re: [Coq-Club] Can Ltac choose a bound variable?, Jason Gross, 06/12/2013
