- From: Pierre Casteran <pierre.casteran AT labri.fr>
- To: Math Prover <mathprover AT gmail.com>
- Cc: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] gensym
- Date: Sun, 16 Jun 2013 07:56:45 +0200
Hi,
You may use "fresh" for generating names that are not
bound in the context yet.
Here is a small example:
Pierre
Ltac bool_case b :=
let h_true := fresh "Ht" in
let h_false := fresh "Hf" in
case_eq b ;[intro h_true|intro h_false].
Goal forall (P: Prop) b, b = negb(negb b).
intros Ht b; bool_case b.
2 subgoals, subgoal 1 (ID 16)
Ht : Prop
b : bool
Ht0 : b = true *** Ht has been renamed to Ht0 because Ht is already used
in the context ***
true = negb (negb true)
subgoal 2 (ID 17) is:
false = negb (negb false)
reflexivity.
reflexivity.
Qed.
Quoting Math Prover
<mathprover AT gmail.com>:
Hi,
1) In a previous question, I learned that I can do:
destruct <expr> eqn:<naming intro pattern>
2) To avoid the use of local variable names, I would like to wrap this in
a ltac. However, I need to provide a name to "eqn: ... ".
Thus, my question -- what is the Coq equiv of gen-sym?
Thanks!
- [Coq-Club] gensym, Math Prover, 06/16/2013
- Re: [Coq-Club] gensym, Pierre Casteran, 06/16/2013
