- To: Math Prover <mathprover AT gmail.com>
- Cc: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Destruct Scoped And
- Date: Mon, 17 Jun 2013 10:05:09 -0400
Here is some code which, I believe, should work, taken (nd cleaned up a bit) from my development at https://bitbucket.org/JasonGross/catdb/src/4eb6407c6ca3200bebefaa3a1834d05c49b01846/Common.v?at=default.
Ltac split_in_context ident funl funr := repeat match goal with | [ H : context p [ident] |- _ ] => let H0 := context p[funl] in let H0' := (eval cbv beta in H0) in assert H0' by apply H; let H1 := context p[funr] in let H1' := (eval cbv beta in H1) in assert H1' by apply H; clear H end. Ltac split_iff := split_in_context iff (fun a b : Prop => a -> b) (fun a b : Prop => b -> a). Ltac split_and' := repeat match goal with | [ H : ?a /\ ?b |- _ ] => let H0 := fresh in let H1 := fresh in assert (H0 := proj1 H); assert (H1 := proj2 H); clear H end. Ltac split_and := split_and'; split_in_context and (fun a b : Prop => a) (fun a b : Prop => b).
-Jason
On Mon, Jun 17, 2013 at 5:16 AM, Math Prover <mathprover AT gmail.com> wrote:
Hi,I want to destruct a "scoped and". See attached tac.v
My existing implementation is somewhat ugly -- for each length, I need to create (a) two lemmas and (b) an extra line in the tactic.I was wondering if there was a simpler way to do this in "one shot"
- [Coq-Club] Destruct Scoped And, Math Prover, 06/17/2013
- Re: [Coq-Club] Destruct Scoped And, Jason Gross, 06/17/2013
- Re: [Coq-Club] Destruct Scoped And, Math Prover, 06/18/2013
- Re: [Coq-Club] Destruct Scoped And, Jason Gross, 06/18/2013
- Re: [Coq-Club] Destruct Scoped And, Vincent Demange, 06/17/2013
- Re: [Coq-Club] Destruct Scoped And, Vincent Demange, 06/18/2013
