- To: Jason Gross <jasongross9 AT gmail.com>
- Cc: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Matching on specific Type argument values?
- Date: Tue, 18 Jun 2013 12:03:35 +0200
On Sun, Jun 16, 2013 at 7:00 PM, Jason Gross
wrote:
> You can only do a syntactic match when you're building a proof in Ltac, not
> within a gallina function. Gallina (the non-Ltac Coq language) doesn't have
> any notion of syntactic equality, and you can't access the definitional
> equality. As a rule of thumb, gallina functions need to respect equality;
> if substituting (propositional) equals for equals changes the behavior of
> the function, then you can't do it in Gallina. You could try Mtac (I've
> never tried it), which, I think, does some tricks with delaying computation
> until you run the code. But I don't think you can prove much about Mtac
> code. Alternatively, you could reify the types you use so that you only
> consider a subset of Type with decidable equality.
I see the problem. Anyway, I've learned that my approach is
ill-adviced anyway. I'm going to change my strategy.
Thanks!
www.mhelvens.net
- [Coq-Club] Matching on specific Type argument values?, Michiel Helvensteijn, 06/16/2013
- Re: [Coq-Club] Matching on specific Type argument values?, Jason Gross, 06/16/2013
- Re: [Coq-Club] Matching on specific Type argument values?, Michiel Helvensteijn, 06/16/2013
- Re: [Coq-Club] Matching on specific Type argument values?, Michiel Helvensteijn, 06/18/2013
