- From: Casteran Pierre <pierre.casteran AT labri.fr>
- To: coq-club AT inria.fr
- Subject: [Coq-Club] Problems with monads
- Date: Fri, 21 Jun 2013 11:03:56 +0200
- Organization: LaBRI - Université Bordeaux 1 - France
Hi,
I met some problems with the "join" function.
using Cédric définitions (taken from Cocorico),
everything seems OK until I try to apply join to
an instance of an inductive family of types.
Happily, bind, return are OK, but a simple application
of join gives me a universe inconsistency.
Perhaps it's the definition of the MM family that is wrong ?
Is there some standard way to solve this issue ?
Pierre
(* from Cedric AUGER in Cocorico *) Class Monad (m : Type -> Type) : Type := {return_ : forall A, A -> m A; bind : forall A, m A -> forall B, (A -> m B) -> m B (* some place for laws *)}. Section monadic_functions. Variable m : Type -> Type. Context ( M : Monad m). Definition join {A:Type} (mma: m (m A)) : m A := bind _ mma _ (fun ma: m A => ma). End monadic_functions. About join. Arguments join { m M A} mma. Inductive MM (B:Type): Type := MM_Return (b:B) | MM_Bind {A :Type}(a:MM A)(f : A -> MM B) | MM_Random (n:nat)(f : nat -> MM B) . Instance MMM : Monad MM. split;[exact MM_Return | intros A ma B f ; exact (MM_Bind _ ma f) ]. Defined. (* Check (fun n : MM (MM nat) => join n): MM (MM nat) -> MM nat. Error: Universe inconsistency. *)
- [Coq-Club] Problems with monads, Casteran Pierre, 06/21/2013
- Re: [Coq-Club] Problems with monads, Casteran Pierre, 06/21/2013
- Re: [Coq-Club] Problems with monads, AUGER Cédric, 06/21/2013
- Re: [Coq-Club] Problems with monads, Arnaud Spiwack, 06/24/2013
- Re: [Coq-Club] Problems with monads, Casteran Pierre, 06/24/2013
