- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Multi-core execution?
- Date: Fri, 21 Jun 2013 16:07:31 +0200
On Thu, Jun 20, 2013 at 07:06:19PM +0200, Pierre-Marie Pédrot wrote:
> For now, it is still quite dumb as you mentioned, as a process is
> forked for each subgoal. It is really a hack, and it would need any
> polishing to be useful, but I wanted to advertise it nonetheless.
I did not look at the code, but I'm curious. What happens if you do:
assert True >> [ abstract( exact I ) | idtac ].
And in the even more trickier case, if you do:
Goal (Type /\ Type) /\ True.
split; [ split >> [ exact Type | exact Type ] | exact Type ].
which is the resulting proof term?
(Conj (Conj Type_i Type_i) Type_i) or (Conj (Conj Type_i Type_j) Type_k)
Ciao
Enrico Tassi
- Re: [Coq-Club] Multi-core execution?, Pierre-Marie Pédrot, 06/20/2013
- Re: [Coq-Club] Multi-core execution?, Enrico Tassi, 06/21/2013
- Re: [Coq-Club] Multi-core execution?, Pierre-Marie Pédrot, 06/21/2013
