- From: "Harley D. Eades III" <harley.eades AT gmail.com>
- To: Duckki Oe <duckki AT mit.edu>
- Cc: coq-club Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] coverage tool
- Date: Mon, 24 Jun 2013 13:52:19 +0200
Hi, everyone.
Great replies thus, far.
Would it not work to print the raw proof terms to a file and then
search those? This would allow one to see exactly when a
particular lemma or definition is used. It would of course take
sometime to generate the proof terms which would be quite large.
Cheers,
.\ Harley
On Jun 23, 2013, at 4:45 PM, Duckki Oe
<duckki AT mit.edu>
wrote:
> Thanks for the replies. I realized my original question was too vague.
> Sorry about that. Yes, because of hint databases, it's not easy to
> identify what's used or not used in proofs (a true dependency analysis). I
> could search the space by removing from hint DB one by one, but it will be
> slow even with automated tools, because my proofs take an hour to compile
> each time. I think we can identify positively what's used by turning all
> the lemmas in question into conjectures and printing assumptions. Then, we
> could possibly take the rest of definitions are not used. I was wondering
> if there is already a tool that can do this.
> -- Duckki
> On Friday, June 21, 2013 at 5:12 PM, Jason Gross wrote:
>> Oh, I see. I interpreted the original question to be "which lemmas are
>> neither used nor put into hint databases".
>> I think my scripts could be modified to first split apart "Hint" lines, so
>> that each hint line only adds one lemma to a database, and then tries, by
>> brute force, to see which hint lines can be removed without making the
>> file fail to compile. After that, it can do a syntactic check. This would
>> be a bit more work than the other version, though most of the
>> infrastructure is already in my scripts.
>> -Jason
>> On Fri, Jun 21, 2013 at 4:43 PM, Nuno Gaspar
>> <nmpgaspar AT gmail.com
>> (mailto:nmpgaspar AT gmail.com)>
>> wrote:
>>> Hello.
>>> Math Prover is right.
>>> For instance, if you have
>>> Lemma SomeLemmaX...
>>> Lemma SomeLemmaY...
>>> Hint Resolve SomeLemmaX SomeLemmaY.
>>> Lemma SomeLemmaZ:
>>> Proof.
>>> auto.
>>> Qed.
>>> The question is: are both used, just one, or none?
>>> I don't think you can answer that simply by syntactical analysis.
>>> Cheers.
>>> 2013/6/21 Jason Gross
>>> <jasongross9 AT gmail.com
>>> (mailto:jasongross9 AT gmail.com)>
>>>> Math Prover: If lem_X is used as a hint by auto/crush, then it must
>>>> appear somewhere else in a "Hint" statement, except in the case that it
>>>> is declared as an Instance rather than as a Definition or Lemma (in
>>>> which case it is automatically added to the typeclass_instances
>>>> database).
>>>> I think the python scripts I wrote to minimize a buggy file (at
>>>> https://github.com/JasonGross/coq-bug-finder) can be used for this. In
>>>> particular, it shouldn't take me more than 0.5-2 hours to write a script
>>>> that will print out all of the definitions, lemmas, etc. of all files
>>>> included into a particular file which are not referenced after some
>>>> point. (Note that it only checks things by name, and so if you have
>>>> overlapping names, it might get confused. It's also recursive, in that
>>>> if you have Lemma A referencing
>>>> Lemma B, but Lemma A is unreferenced, then Lemma B also counts as
>>>> unreferenced, unless Lemma A appears after the cut-off point. If you
>>>> want, I can change this, too.) If you want me to, I can do this in the
>>>> next few days, or you can try it yourself (the relevant bit is
>>>> "try_remove_definitions" in find-bug.py). If you want me to do it, I'd
>>>> need a clearer idea of what you want to do, and possibly an example
>>>> repository (for example, it currently doesn't deal well with nested
>>>> directory structure).
>>>> -Jason
>>>> On Fri, Jun 21, 2013 at 9:38 AM, Math Prover
>>>> <mathprover AT gmail.com
>>>> (mailto:mathprover AT gmail.com)>
>>>> wrote:
>>>>> I think the problem here is
>>>>>> "I put lemmas in hint databases"
>>>>> Therefore, an emacs module that merely parses the *.v file won't
>>>>> suffice, because it's possible that there is some Lemma lem_X, where:
>>>>> *) the name lem_X does not appear anywhere else
>>>>> *) however lem_X is used as as rewrite/resolve hint used by auto/crush
>>>>> On Fri, Jun 21, 2013 at 6:35 AM, Kenneth Adam Miller
>>>>> <kennethadammiller AT gmail.com
>>>>> (mailto:kennethadammiller AT gmail.com)>
>>>>> wrote:
>>>>>> You could write a definition for the coq language using Semantic in
>>>>>> Emacs
>>>>>> http://www.gnu.org/software/emacs/manual/html_node/emacs/Semantic.html
>>>>>> Semantic goes the extra mile in extensible and configurable editors
>>>>>> like
>>>>>> Emacs by striving to rigorously understand the language and its
>>>>>> syntax. So
>>>>>> if you wrote that, not only would you be helping the open source
>>>>>> community,
>>>>>> but you would also provide yourself with a way to colorize all the
>>>>>> un-referenced definitions/theorems in a module. And if you can colorize
>>>>>> them, you can put it into a configurable script!
>>>>>> On Thu, Jun 20, 2013 at 3:00 PM, Duckki Oe
>>>>>> <duckki AT mit.edu
>>>>>> (mailto:duckki AT mit.edu)>
>>>>>> wrote:
>>>>>>> Hi,
>>>>>>> Is there a tool that can detect unreferenced definitions/theorems in a
>>>>>>> module (or modules)? I'd like to clean up my modules and remove
>>>>>>> unnecessary
>>>>>>> lemmas. But, I put lemmas in hint databases and it'll be very time
>>>>>>> consuming
>>>>>>> to manually test if every single lemma is used. Thanks!
>>>>>>> -- Duckki
>>> Bart: Look at me, I'm a grad student, I'm 30 years old and I made $600
>>> dollars last year.
>>> Marge: Bart! Don't make fun of grad students, they just made a terrible
>>> life choice.
- [Coq-Club] coverage tool, Duckki Oe, 06/20/2013
- Re: [Coq-Club] coverage tool, Kenneth Adam Miller, 06/21/2013
- Re: [Coq-Club] coverage tool, Math Prover, 06/21/2013
- Re: [Coq-Club] coverage tool, Jason Gross, 06/21/2013
- Re: [Coq-Club] coverage tool, Nuno Gaspar, 06/21/2013
- Re: [Coq-Club] coverage tool, Duckki Oe, 06/23/2013
- Re: [Coq-Club] coverage tool, Harley D. Eades III, 06/24/2013
- Re: [Coq-Club] coverage tool, Nuno Gaspar, 06/24/2013
- Re: [Coq-Club] coverage tool, Jason Gross, 06/24/2013
