- To: coq-club AT inria.fr
- Subject: [Coq-Club] Coercion from nat to nat_modulo_N
- Date: Tue, 25 Jun 2013 12:04:59 +0200
I have a type "nat_mod". So, "nat_mod 3" are the natural numbers modulo 3. Obviously, "nat_mod 3 1" will be equal to "nat_mod 3 4".
I feel like Coq, in a given context, should be able to coerce a "nat" into a "nat_modulo <N>".
The code looks something like:
(* This will change... *)
Definition nat_mod (n:nat) : Type
:= {x | x < n}.
Theorem nat_mod_from_nat {n:nat} (x : nat) : nat_mod n.
Admitted.
(* This fails: *)
Coercion nat_mod_from_nat : nat >-> nat_mod.
Check (10 : nat_mod 5).
Basically, the problem seems to be that I can't pick up the modulo value from the context. (It can't figure out the implicit parameter "n" of "nat_mod_from_nat".)
Coq accepts if I do:
Coercion nat_mod_from_nat : nat >-> Funclass.
But I don't know what "Funclass" means.
Can Coq do what I want?
Mike
- [Coq-Club] Coercion from nat to nat_modulo_N, Michael Nahas, 06/25/2013
