coq-club - Re: [Coq-Club] ltac "remember _ as _ eqn: _" ignoring eqn name
  • To: Jason Gross <jasongross9 AT gmail.com>
  • Cc: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] ltac "remember _ as _ eqn: _" ignoring eqn name
  • Date: Tue, 25 Jun 2013 11:04:57 -0700
I'm on OSX 10.8.3
Here's coqtop.opt-v, the fail.v, and the output of running it under coqtop.opt
$ coqtop.opt -v ; echo "**********"; cat fail.v; echo "**********"; cat fail.v | coqtop.opt
The Coq Proof Assistant, version 8.4 (September 2012)
compiled on Sep 25 2012 15:01:39 with OCaml 3.12.1
Ltac simp_rem v :=
  let nV := fresh "var_" in
  let nH := fresh "H_eq_var_" in
    remember v as nV eqn:nH.
Lemma lem_000:
  forall (a : nat), (a+2) = 2.
Proof.
  intro a.
  simp_rem (a+2).
Welcome to Coq 8.4 (September 2012)
Coq < Coq < Coq < Coq < simp_rem is defined
Coq < Coq < Coq < 1 subgoal
   forall a : nat, a + 2 = 2
lem_000 < 1 subgoal
lem_000 < 1 subgoal
  a : nat
   a + 2 = 2
lem_000 < 1 subgoal
  a : nat
  var_ : nat
  nH : var_ = a + 2
   var_ = 2
lem_000 < lem_000 < lem_000 <
On Tue, Jun 25, 2013 at 10:58 AM, Jason Gross <jasongross9 AT gmail.com> wrote:
Which version of Coq are you using?  In both 8.4pl2 and trunk from a few months ago, copy/pasting your new code (which is indeed what I meant) gives me (approximately):
1 subgoals, subgoal 1 (ID 7)
  a : nat
  var_ : nat
  H_eq_var_ : var_ = a + 2
   var_ = 2
(dependent evars:)
On Tue, Jun 25, 2013 at 1:42 PM, t x <txrev319 AT gmail.com> wrote:
Hi Jason,
  I tried the following, and it still says nH. Did I misinterpret your response?
Ltac simp_rem v :=
Lemma lem_000:
Proof.
  intro a.
  simp_rem (a+2).
(* output:
1 subgoal
a : nat
var_ : nat
nH : var_ = a + 2
====================================================================== (1/1)
var_ = 2
  Abort.
On Mon, Jun 24, 2013 at 8:51 PM, Jason Gross <jasongross9 AT gmail.com> wrote:
Remove the space after "eqn:".  I'm not sure why this doesn't raise a warning or error, as remember doesn't otherwise take multiple arguments...
-Jason
On Mon, Jun 24, 2013 at 10:08 PM, t x <txrev319 AT gmail.com> wrote:
Hi,
Consider the following block of code:
== BEGIN ==
Ltac simp_rem v :=
    remember v as nV eqn: nH.
Lemma lem_000:
Proof.
  intro a.
  simp_rem (a+2).
  Abort.
== END ==
The output I get is:
1 subgoal
a : nat
var_ : nat
nH : var_ = a + 2
var_ = 2
I like the fact that the newly introduced var has prefix "var_"
I don't like the fact that the equation is named nH instead of something with prefix "H_eq_var_"
It is important to me that (1) I don't clash with existing hypothesis names and (2) I know the name of the newly introduced equation so that I can apply other transforms to it.
Question:
1) What am I doing wrong?
2) How do I fix this?
