coq-club - [Coq-Club] Dependent Types vs passing around props
  • To: coq-club <coq-club AT inria.fr>
  • Subject: [Coq-Club] Dependent Types vs passing around props
  • Date: Fri, 28 Jun 2013 11:15:51 -0700
Hi,
Short question: what am I doing wrong with dependent-types?
Long question: consider this example here:
https://gist.github.com/anonymous/ebbf5a5fc3be7b0f0bfa
We have
  inRange, validRange, validIndex
both as _prop and as _dtype.
Imagine we have:
  (1) lst: a list,
  (2) r: a valid range of the list
  (3) i: a element in range r
and we want to call a function which takes:
  (1) lst: the above list
  (2) i: above i, with proof its a validIndex of lst
Now, in the _prop world, this transform can be phrased as lem_000_prop (line 39). In the _dtype world, how do I phrase this?
In particular, I get stuck on the following:
  * in the _prop world, $i$ is a Z, with property that it's inRange r, and I want to to show that $i$ also has property validIndex lst
  * in the _dtype world, $i$ has type {i: nat| inRange r i}, and I want to construct something of dtype validIndex lst -- so somehow, I want to say:
  there exists an $j$ of type validIndex lst,
    where proj1_sig j = proj1_sig i
  (because I want to use "the same" i)
  Naively, to me, it appears the _prop world is better since it's easier to say "use the same i; we're now going to show it has more properties" whereas the _dtype world I have to say "well, there exists an element of type validIndex lst, such that their proj1_sig are the same"
Clearly I'm misunderstanding something. What am I doing wrong?
(I've looked at chapter 6 of CPDT, I don't see anything that adresses my particular problem.)
  • [Coq-Club] Dependent Types vs passing around props, t x, 06/28/2013
