- To: "Vincent Siles" <vincent.siles AT ens-lyon.org>
- Cc: mtkhan AT risc.uni-linz.ac.at, "Coq-Club Club" <coq-club AT inria.fr>, pierre.boutillier AT inria.fr
- Subject: Re: [Coq-Club] Computing function results
- Date: Mon, 1 Jul 2013 15:13:11 +0200 (CEST)
- Importance: Normal
Hi Vincent and Pierre,
Yea these worked for the isDDO case. What about the other function
isAddo? Any clue here?
Thanks.
taimoor
> Dear tk,
> you can try to assert a specialized version of your axiom and then use
> it to rewrite your goal, something like:
> assert (HH := isDDO_def nil a1 b0 b).
> simpl in HH.
> rewrite HH.
> I'm pretty sure there is a nicer way to do this, but I don't know it :)
> Cheers,
> V.
> 2013/7/1
> <mtkhan AT risc.uni-linz.ac.at>:
>> Dear Adam,
>> Thanks for your response. I do agree with you that the selection of
>> right constructs for defining functions (or any other logical prop)
>> helps in proving and also to find inconsistency in the theory, if there
>> is any.
>> However, I get this proof situation automatically translated from
>> a verification tool Why3 (http://why3.lri.fr); so in some sense
>> I have to live with it ;)
>> So any clue here?
>> regards,
>> tk
>>> Has someone suggested before giving proper definitions of your
>>> identifiers with [Inductive] and [Fixpoint] rather than [Parameter] and
>>> [Axiom]? Coq users tend to be skeptical of any development using
>>> axioms
>>> in the way that you are. You certainly get much more convenient term
>>> simplification doing things more idiomatically. If you _can't_ define
>>> your notions constructively, then how are you convincing yourself that
>>> they are logically consistent?
>>> On 07/01/2013 05:10 AM,
>>> wrote:
>>>> I have the following function definitions of isDDO and isAddo:
>>>> Parameter isAddo: addo -> bool.
>>>> Parameter isDDO: (list (symbol* (list Z)* (list Z)* symbol)%type) ->
>>>> Z
>>>> -> Z
>>>> -> (list symbol) -> bool.
>>>> Axiom isDDO_def : forall (a:(list (symbol* (list Z)* (list Z)*
>>>> symbol)%type))
>>>> (anzdelta:Z) (anzsigma:Z) (g:(list symbol)),
>>>> match a with
>>>> | Nil => ((isDDO a anzdelta anzsigma g) = true)
>>>> | (Cons e l) => (((isDDOTerm e anzdelta anzsigma g) = true) ->
>>>> ((isDDO a
>>>> anzdelta anzsigma g) = (isDDO l anzdelta anzsigma g))) /\
>>>> ((~ ((isDDOTerm e anzdelta anzsigma g) = true)) -> ((isDDO a
>>>> anzdelta
>>>> anzsigma g) = false))
>>>> end.
>>>> Axiom isAddo0 : forall (a:addo), ((isAddo a) = true) -> forall (n:Z),
>>>> ((0%Z<= n)%Z /\ (n< (length_addo a))%Z) ->
>>>> ((isAddo_term (get_addo_data a) (get_addo_term a n)) = true).
>>>> In the first goal, I simply need to compute the function results
>>>> and it should simply work.
- [Coq-Club] Computing function results, mtkhan, 07/01/2013
- Re: [Coq-Club] Computing function results, Adam Chlipala, 07/01/2013
- Re: [Coq-Club] Computing function results, mtkhan, 07/01/2013
- Re: [Coq-Club] Computing function results, Vincent Siles, 07/01/2013
