- From: Alan Schmitt <alan.schmitt AT polytechnique.org>
- To: Gyesik Lee <leegys AT gmail.com>
- Cc: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Compilation question of GroupTheory (User's contribution)
- Date: Tue, 02 Jul 2013 09:35:33 +0200
leegys AT gmail.com
writes:
> The user's contribution library GroupTheory can be well compiled just by
> using the command 'make'.
> However, when I like to use g1.v, I cannot pass the following line:
> Require Import Laws.
> Emacs + ProofGeneral complains as below:
> Error: The file ..../GroupTheory/Laws.vo contains library
> GroupTheory.Laws and not library Laws
Since you're using ProofGeneral, you could create a file
`.dir-locals.el' with the appropriate include path. For instance, if the
path where GroupTheory is install is "../foo/GroupTheory", you could say:
--8<---------------cut here---------------start------------->8---
((coq-mode . ((coq-load-path . (("../foo/GroupTheory" "GroupTheory"))))))
--8<---------------cut here---------------end--------------->8---
You can do a `C-h v coq-load-path' to know more about what this variable
means.
Hope this helps,
Alan
- [Coq-Club] Compilation question of GroupTheory (User's contribution), Gyesik Lee, 07/02/2013
- Re: [Coq-Club] Compilation question of GroupTheory (User's contribution), Alan Schmitt, 07/02/2013
- Re: [Coq-Club] Compilation question of GroupTheory (User's contribution), Pierre Courtieu, 07/02/2013
- Re: [Coq-Club] Compilation question of GroupTheory (User's contribution), Gyesik Lee, 07/03/2013
