coq-club - [Coq-Club] "conditional" ltacs
  • To: coq-club <coq-club AT inria.fr>
  • Subject: [Coq-Club] "conditional" ltacs
  • Date: Tue, 9 Jul 2013 13:29:32 -0700
Hi,
  (1) unrelated to actual question: from observing the list, is it correct that rich HTML is actually _encouraged_ for this list as long as it makes the code easier to read?
  (2) actual question:
I want to write a ltac that says: "apply this lemma, if and only if the newly introduced goals can be solved by omega"
For example, consider this minimal example:
Lemma silly:
  forall a,
    a < 10 -> a < 20.
Proof.
  intros. omega. Qed.
Ltac tst :=
match goal with
| |- ?a < 20 => apply silly
end.
Lemma silly2:
  5 < 20.
  tst. (* good *) Abort.
Lemma silly3:
  15 < 20.
  tst. (* bad *) Abort.
whenever we do "apply silly", it induces a new goal "a < 10"
I want to be able to say:
  when you see ?x < 20,
    do apply silly, _only if_ ?x < 10 can be solved by omega
So I want it to fire in case silly2, but to leave the goal un-changed in case silly3.
Can someone show me the idiomatic solution to this?
Thanks!
