- From: Abhishek Anand <abhishek.anand.iitg AT gmail.com>
- To: coq-club <coq-club AT inria.fr>
- Subject: [Coq-Club] unfold causes out of memory
- Date: Fri, 12 Jul 2013 00:18:02 -0400
I have a function (say f1) defined as a Fixpoint containing 70 lines of Coq code.
When I do Print f1, coq shows me ~4000 lines. I guess it compiles the compact
pattern matches into simple ones. unfolding f1 in proofs at some(but not all) places causes out of memory error after waiting >20 minutes. I suspect it unfolds the fixpoint multiple times.
I think I once noticed that on unfolding, the recursive calls were fully expanded.
(At that time f1 was much simpler, but it still took minutes)
In my proofs, I only want to unfold it exactly once. Is there some way to do it.
On searching with google, I could find only http://coq.inria.fr/cocorico/UnfoldFixpointOnce
I can try it if there is no other way.
(I'm not so keen on building from sources on my windows machine to get the development libraries that it requires)
-- Abhishek
- [Coq-Club] unfold causes out of memory, Abhishek Anand, 07/12/2013
- Re: [Coq-Club] unfold causes out of memory, Enrico Tassi, 07/12/2013
