Re: [Coq-Club] Interactive 'match' tactic (or treating 'case' more like 'match')?
- To: Michiel Helvensteijn <mhelvens AT gmail.com>
- Cc: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Interactive 'match' tactic (or treating 'case' more like 'match')?
- Date: Sun, 14 Jul 2013 13:04:02 -0400
On 07/14/2013 11:14 AM, Michiel Helvensteijn wrote:
On Sun, Jul 14, 2013 at 4:37 PM, Adam
Chlipala<adamc AT csail.mit.edu>
wrote
I suggest looking into an even more automated proof style (described in CPDT),Sounds good. Could you perhaps point me to the right chapter or give
me an example of the technique you would recommend in my case?
It's hard to point to a specific chapter. Chapter 14 is most directly relevant, but the earlier chapters build up to that point by applying an automated proof style from the start.
where there is no inherent case order in your scripts, not even at the levelThe only inherent case order in my `match` script is that the wildcard
found in your first script below.
pattern never matches `case2` because it is given last. And that might
actually be considered a "good thing", as it saves typing.
Maybe, though, your problem domain actually admits some simple proof automation, such that there's no need to think about case split details yourself.
- [Coq-Club] Interactive 'match' tactic (or treating 'case' more like 'match')?, Michiel Helvensteijn, 07/14/2013
- Re: [Coq-Club] Interactive 'match' tactic (or treating 'case' more like 'match')?, Adam Chlipala, 07/14/2013
- Re: [Coq-Club] Interactive 'match' tactic (or treating 'case' more like 'match')?, Michiel Helvensteijn, 07/14/2013
- Re: [Coq-Club] Interactive 'match' tactic (or treating 'case' more like 'match')?, Jason Gross, 07/14/2013
