Re: [Coq-Club] Mutually recursive function with structurally decreasing argument pair?
- From: Jacques-Henri Jourdan <jacques-henri.jourdan AT inria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Mutually recursive function with structurally decreasing argument pair?
- Date: Mon, 15 Jul 2013 10:18:31 +0200
Does the following fits your needs ?
Fixpoint f (a:nat) :=
(fix frec b :=
match a with
| O => 0
| S a' => f a' b + g a' b
end +
match b with
| O => 0
| S b' => frec b' + grec b'
end
with grec b :=
match a with
| O => 0
end +
match b with
| O => 0
| S b' => grec b'
end
for frec)
with g (a:nat) :=
(fix frec b :=
match a with
| O => 0
end +
match b with
| O => 0
end
with grec b :=
match a with
| O => 0
end +
match b with
| O => 0
| S b' => grec b'
end
for grec).
I was searching how to do that without code replication, but I have no Idea for now.
JH
Le 15/07/2013 00:44, Michiel Helvensteijn a écrit :
Hi all,
I have two mutually recursive functions with two arguments each
(simplified example):
Fixpoint f (a: T) (b: U) : V := ...
with g (a: T) (b: U) : V := ...
I know that they terminate because, as a pair, the arguments are
structurally decreasing. That is to say, in `f`, `a` decreases and `b`
is passed unchanged, and in `g`, `a` is passed unchanged and `b`
decreases.
`Fixpoint` accepts only a single decreasing argument as evidence for
termination. Apparently the `Function` construct is more flexible
w.r.t. termination evidence, but not, it seems, for mutual recursion.
Sure, I could add a third argument to decrease on, such as a `c: nat`
containing the sum of the structural depths of `a` and `b`. But that
would involve a lot of tedious boilerplate code, not to mention
preconditions and proofs of the fact that `c` always remains large
enough.
Is there a technique or construct I'm unaware of? Something that will
make this easier?
Thanks in advance!
www.mhelvens.net
- [Coq-Club] Mutually recursive function with structurally decreasing argument pair?, Michiel Helvensteijn, 07/15/2013
- Re: [Coq-Club] Mutually recursive function with structurally decreasing argument pair?, t x, 07/15/2013
- Re: [Coq-Club] Mutually recursive function with structurally decreasing argument pair?, Michiel Helvensteijn, 07/15/2013
- Re: [Coq-Club] Mutually recursive function with structurally decreasing argument pair?, Adam Chlipala, 07/15/2013
- Re: [Coq-Club] Mutually recursive function with structurally decreasing argument pair?, AUGER Cédric, 07/15/2013
- Re: [Coq-Club] Mutually recursive function with structurally decreasing argument pair?, Jacques-Henri Jourdan, 07/15/2013
