- To: Michiel Helvensteijn <mhelvens AT gmail.com>
- Cc: Adam Chlipala <adamc AT csail.mit.edu>, coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] How to prove that inductive substructures are not equal?
- Date: Mon, 15 Jul 2013 19:49:38 +0200
If you take a closer look at A. Chipala answer, he used the "induction" tactic.
You didn’t. congruence is not enough smart to reason by induction.
The bad thing is that Coq does not have a nice way to deal with mutual induction.
There are many ways to do it, but none of them are really friendly.
You can try to start with:
Lemma foo : ∀ x, (shapeA (shapeA' x)) ≠ x
with bar : ∀ y, (shapeA' (shapeA y)) ≠ y.
Proof. (* foo *)
intros [y|].
* (* shapeA (shapeA' (shapeA y)) ≠ shapeA y *)
generalize (bar y); clear foo bar.
<do your proof here>
* (* shapeA (shapeA' shapeB) ≠ shapeB *)
clear foo bar.
Proof. (* bar *)
intros [x|].
Proof. (* foo *)
intros [y|].
clear foo bar.
Proof. (* bar *)
intros [x|].
* (* shapeA' (shapeA (shapeA' y)) ≠ shapeA' y *)
* (* shapeA' (shapeA shapeB') ≠ shapeB' *)
clear foo bar.
Qed.
I did not tried it, for the <do your proof here>, the congruence tactic A. Chipala told of can be useful.
Note that if you do the proof this way, the "clear foo bar." might not be necessary, but I highly advise it.
You can also take a look at "Induction Scheme" in the manual. I never use it personally, but I do not think either it is bad taste to use it.
.../Sedrikov\...
clear foo bar.
Qed.
.../Sedrikov\...
- [Coq-Club] How to prove that inductive substructures are not equal?, Michiel Helvensteijn, 07/15/2013
- Re: [Coq-Club] How to prove that inductive substructures are not equal?, Adam Chlipala, 07/15/2013
- Re: [Coq-Club] How to prove that inductive substructures are not equal?, Michiel Helvensteijn, 07/15/2013
- Re: [Coq-Club] How to prove that inductive substructures are not equal?, Cedric Auger, 07/15/2013
