- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] The Proof of palindrome
- Date: Wed, 24 Jul 2013 11:11:19 -0400
On 07/23/2013 02:31 PM, Daniel Schepler wrote:
On Mon, Jul 22, 2013 at 11:32 PM,
fengsheng<fsheng1990 AT 163.com>
wrote:
Hello everyone:
I met a question of palindrome,the following is my definition of
palindrome:
Inductive pal {X : Type} : (list X) -> Prop :=
| pal_empty : pal []
| pal_single : forall (x : X), pal [x]
| pal_app: forall (x : X) (l: list X), pal l -> pal (x::(snoc l x)).
Now, I want to prove:
THeorem forall l, l = rev l -> pal l.
But I counld not work it out.
Counld you give me a proof of the theorem?
Here's another proof that is mostly automated. More or less all you need is a lemma about decomposing a list into its last element and the rest.
Require Import List Omega.
Set Implicit Arguments.
Hint Extern 1 (_ <=_ ) => omega.
Inductive pal {X : Type} : list X -> Prop :=
| pal_empty : pal nil
| pal_single : forall (x : X), pal (x :: nil)
| pal_app: forall (x : X) (l: list X), pal l -> pal (x :: l ++ x :: nil).
Hint Constructors pal.
Ltac t := simpl; repeat (autorewrite with list in *; simpl in *;
repeat match goal with
| [ H : ex _ |- _ ] => destruct H
| [ H : _ :: _ = _ :: _ |- _ ] => injection H; clear H; intros; subst
end;
intuition (try congruence; try omega; eauto; try subst)).
Lemma app_nil : forall A (ls : list A),
ls = nil ++ ls.
t.
Qed.
Lemma app_cons : forall A (a : A) ls a',
a :: ls ++ a' :: nil = (a :: ls) ++ a' :: nil.
t.
Qed.
Hint Immediate app_nil app_cons.
Lemma has_last : forall A (ls : list A),
ls = nil \/ exists ls' a, ls = ls' ++ a :: nil.
induction ls; t.
Qed.
Lemma deapp : forall A (a : A) ls1 ls2,
ls1 ++ a :: nil = ls2 ++ a :: nil
-> ls1 = ls2.
intros; do 2 (apply (f_equal (@rev _)) in H; t).
Qed.
Hint Immediate deapp.
Lemma pal_complete' : forall A n (l : list A), length l <= n
-> l = rev l -> pal l.
induction n; destruct l; t;
specialize (has_last l); t.
Qed.
Theorem pal_complete : forall A (l : list A), l = rev l -> pal l.
eauto using pal_complete'.
Qed.
- [Coq-Club] The Proof of palindrome, fengsheng, 07/23/2013
- Re: [Coq-Club] The Proof of palindrome, Vincent Siles, 07/23/2013
- Re: [Coq-Club] The Proof of palindrome, Daniel Schepler, 07/23/2013
- Re: [Coq-Club] The Proof of palindrome, Adam Chlipala, 07/24/2013
