coq-club - Re: [Coq-Club] A better way to address a tricky inversion?
  • From: Valentin Robert <valentin.robert.42 AT gmail.com>
  • To: AUGER Cédric <sedrikov AT gmail.com>
  • Cc: "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] A better way to address a tricky inversion?
  • Date: Sun, 28 Jul 2013 18:02:55 +0100
I see, so the idea is:
- Destructing t in the context "eval_term t < 42" is not going to
work, because the context is ill-typed for other concrete indices than
t's one.
- So we can replace the goal with "P d (eval_term t)", such that "P
natD (eval_term t)" reduces to the current goal, and "P d (eval_term
t)" reduces to something trivial for other indices.
- In the context "P d (eval_term t)" it is fine to destruct t. We
successfully turned ill-typed goals into vacuous goals.
So really, my first step could have been:
dependent inversion_clear t with (fun d t =>
match d as _d return [[_d]] -> Prop with
| natD => fun v => v < 42
| _ => fun _ => True
end (eval_term env t)
which turns in two goals easily solved.
Thanks for the help!
- Valentin
On Sun, Jul 28, 2013 at 4:11 PM, AUGER Cédric
wrote:
> Le Sun, 28 Jul 2013 08:38:38 +0100,
> Valentin Robert
> a écrit :
>> Hello club,
>> Standalone code here: http://paste.awesom.eu/Ptival/sJU&ln
>> The gist of my problem is as follows. I defined a typed language of
>> terms, similar to this:
>> Inductive term : desc -> Type :=
>> | NatLit (n: nat) : n < 42 -> term natD
>> | BoolLit : bool -> term boolD
>> | Var (i: fin (projT1 envD)) : term (vec_ith envD i)
>> Each base type has a description (natD denotes nat, boolD denotes
>> bool). Every term is indexed by the description of its type.
>> In particular, Vars index safely into an environment whose description
>> is a vector of base descriptions.
>> Notice the silly requirement that natural literal numbers are bounded
>> by 42.
>> A simple evaluator is defined as (an environment env of description
>> envD is in the section's scope):
>> Definition eval_term (d: desc) (t: term d) : [[d]] :=
>> match t with
>> | NatLit n _ => n
>> | BoolLit b => b
>> | Var i => hvec_ith (existT denote envD env) i
>> end.
>> It guaranteedly returns a value of the expected type.
>> I set to prove that a certain property is always true for all natural
>> numbers resulting from an evaluation, knowing it is true for natural
>> literals, and true for all natural numbers living in my current
>> environment:
>> Definition invariant (envD: vec desc) (env: [[envD]]) :=
>> all_nats (fun n => n < 42) envD env.
>> Theorem ok :
>> forall (envD: vec desc) (env: [[envD]]) (t: term envD natD),
>> invariant envD env ->
>> eval_term env t < 42.
>> In the proof of this theorem, given in the linked URL, I eventually
>> reached this state:
>> match vec_ith envD i as _d return (term envD _d -> Prop) with
>> | natD => fun tin : term envD natD => eval_term env tin < 42
>> | boolD => fun _ : term envD boolD => True
>> end (Var envD i)
>> At that point, I am unable to continue using Coq tactics.
>> I cannot abstract over (vec_ith envD i) because it makes the
>> application with (Var envD i) ill-typed.
>> I cannot generalize (Var envD i) because its concrete value is needed
>> to compute eval_term after the match.
>> What I do in the proof is write my own dependent pattern match,
>> allowing me to shove (Var envD i) inside eval_term, having carefully
>> wrapped it inside a type cast.
>> forall EQ : vec_ith envD i = natD,
>> eval_term env
>> match EQ in (_ = __vi) return (term envD __vi) with
>> | eq_refl => Var envD i
>> end < 42
>> From then on, I manage to push eval_term inside the cast, perform the
>> beta reduction, and prove the remaining goal using my hypotheses.
>> I find these parts of the proof very cumbersome and brittle: in my
>> example, the language is much more involved, and writing this big
>> "refine" is unsatisfactory.
>> Is there a more clever way to address this (ll. 166-195 in the given
>> link)?
>> I hope to turn this example into a blog post explaining how inversions
>> can become complicated (and the infamous "Abstracting over ... leads
>> to a term ... which is ill-typed"), and I would like to display good
>> solutions, if possible! (with all credits due if you provide one)
>> Comments much appreciated!
>> Best regards,
>> - Valentin
> What about:
> Theorem ok :
> Proof.
> intros envD env t INV.
> set (P := fun d => match d as d0 return [[d0]] -> Prop with
> | natD => fun e => e < 42 | boolD => fun _ => True
> end). change (P natD (eval_term env t)).
> case t; subst P; simpl; auto; clear t; destruct envD; simpl in *.
> unfold vec_ith, hvec_ith, denote_vec, invariant, all_nats in *; simpl
> in *.
> induction x; simpl in *.
> intros [].
> destruct v, env, INV.
> intros [f|]; simpl in *; auto.
> now apply IHx.
> Qed.
