coq-club - Re: [Coq-Club] should typecheck... right
  • To: Cedric Auger <sedrikov AT gmail.com>
  • Cc: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] should typecheck... right
  • Date: Thu, 1 Aug 2013 18:47:08 +0200
Well, in short I'm not able to reproduce your example from [1]
And apparently my attempt of simplifying it destroyed the original problem :-)
I believe it is similar though.. I get a
The term "p_lb_dec lb0 Hp" has type
 "dec (forall b' : box, In b' nil -> p b')" while it is expected to have type
 "dec (forall b' : box, In b' lb0 -> p b')".
when trying to typecheck [p_lb_dec] .
I'm not even sure how you didn't have this problem yourself..
I'm running Coq 8.4 if that matters..
[1] https://sympa.inria.fr/sympa/arc/coq-club/2013-02/msg00057.html
2013/8/1 Cedric Auger <sedrikov AT gmail.com>
2013/8/1 Nuno Gaspar <nmpgaspar AT gmail.com>
Hello.
Well, I'm having an hard time reproducing an example I was given. I think I can resume it to the following (I'm actually not sure my simplification didn't break the original problem...but heh)
Here follows:
Parameter l : list nat.
Parameter x_nil     : forall n:nat, In n nil.
Parameter x_not_nil : forall (n:nat), In n l.
Fixpoint test l  :=
  match l with
    nil      => x_nil
  | cons e r => x_not_nil
  end.
I imagine you can guess my doubt.. So why doesn't it typecheck? They both live in Prop...  -_-
No.
[True] lives in [Prop].
[False] lives in [Prop].
but
[x_nil] lives in [∀ n, In n nil] (which in turns lives in [Prop], but [x_nil] does not).
Note also that your context is inconsistant, I do not think that what you wrote is what you wanted.
Plus the 'l' in the type of 'x_not_nil' is not the same as the one bound in your [test] fixpoint.
Now, if you want to make it typecheck, you should first know exactly what you want.
For instance I do not know:
– the expected type of [test] (is it "list nat → Prop" ?)
– why you put a fixpoint in a function which does not do any recursion (from my point of view, it is bad taste to put a "Fixpoint" keyword where a "Definition" keyword would work)
.../Sedrikov\...
Bart: Look at me, I'm a grad student, I'm 30 years old and I made $600 dollars last year.
Marge: Bart! Don't make fun of grad students, they just made a terrible life choice.
