- From: Kristopher Micinski <krismicinski AT gmail.com>
- To: Nuno Gaspar <nmpgaspar AT gmail.com>
- Cc: Adam Chlipala <adamc AT csail.mit.edu>, coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] bug or feature
- Date: Fri, 2 Aug 2013 14:25:36 -0400
You have it backwards: the constructor is I, True is the thing in the Prop:
Inductive True : Prop := I : True
Kris
On Fri, Aug 2, 2013 at 12:13 PM, Nuno Gaspar
wrote:
> ohh, I get it now, lol
> My confusion was due to the fact that I meant True as the one in Prop, and
> not a constructor element :x
> 2013/8/2 Adam Chlipala
>> It doesn't look like a bug to me. Coq uniformly enforces a rule that a
>> given "global" identifier may only be defined once per scope (e.g., module)
>> that permits "global" identifier definitions.
>> On 08/02/2013 12:03 PM, Nuno Gaspar wrote:
>>> I believe this is a bug, but then again probably it would have been
>>> noticed by now..
>>> Inductive one : Prop := True.
>>> Inductive two : Prop := True.
>>> You won't be able to evaluate the second definition.
> Bart: Look at me, I'm a grad student, I'm 30 years old and I made $600
> dollars last year.
> Marge: Bart! Don't make fun of grad students, they just made a terrible life
> choice.
- [Coq-Club] bug or feature, Nuno Gaspar, 08/02/2013
- Re: [Coq-Club] bug or feature, Adam Chlipala, 08/02/2013
- Re: [Coq-Club] bug or feature, Nuno Gaspar, 08/02/2013
- Re: [Coq-Club] bug or feature, Kristopher Micinski, 08/02/2013
