- From: Anton Tayanovskyy <anton.tayanovskyy AT gmail.com>
- To: Helmut Brandl <helmut.luis.brandl AT gmail.com>
- Cc: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Program extraction / Beginners question
- Date: Sat, 3 Aug 2013 19:53:57 -0400
You can perhaps write a few axioms defining the interface for
immutable arrays (vectors), and then implement them in OCaml, say:
Parameter vec : forall (a : Type), Type.
Parameter nth : forall {a}, vec a -> nat -> option a.
Parameter init : forall {a}, nat -> (nat -> a) -> vec a.
Definition test :=
let x := init 3 (fun x => x + 1) in
nth x 2.
Extraction test.
Thanks,
--A
On Sat, Aug 3, 2013 at 5:34 PM, t x
<txrev319 AT gmail.com>
wrote:
> For ints,
> there are:
> (1) "nat" which consists of:
> O = 0
> S(n) = n+1
> (2) Z, which consists of:
> Zpos, Zneg, Z0; where Zpos/Zneg use binary representations (xH, xO, xI).
> For arrays, texts I've read suggested representing "T arr[];" as "f: nat ->
> T"
> However, in practice, I found it (for the sake of eval compute and proving
> things) easier if I represented arrays as an associative list. [Of course,
> you will have to do some black magic (beyond my abilities) for telling Coq
> to map the associative list operations to array ops rather than actual
> associative list ops.]
> On Sat, Aug 3, 2013 at 1:24 PM, Helmut Brandl
> wrote:
>> Hello all,
>> I am writing a verifying compiler and I use ocaml as the implementation
>> language. I would like to use coq to verify some critical algorithms.
>> I have already read some documentation on program extraction. With
>> inductive types I don't see any problems, because inductive types and
>> functions on inductive types are translated one to one (with some
>> lexical adaptions and proof deletion) from coq to ocaml.
>> However I need arrays and I need to index arrays with ints in my
>> program. The algorithms I am trying to verify do not use the mutability
>> of ocaml arrays but they use the contents.
>> Can anybody give me hints (or links to any documentation) on how to
>> represent arrays and ints in coq?
>> Thanks
>> Helmut
Kind Regards,
Anton Tayanovskyy
WebSharper™ - type-safe JavaScript in F#
http://intellifactory.com
- [Coq-Club] Program extraction / Beginners question, Helmut Brandl, 08/03/2013
- Re: [Coq-Club] Program extraction / Beginners question, t x, 08/03/2013
- Re: [Coq-Club] Program extraction / Beginners question, Anton Tayanovskyy, 08/04/2013
