- To: Daniel Schepler <dschepler AT gmail.com>
- Cc: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] matching on proofs?
- Date: Fri, 16 Aug 2013 09:15:55 +0000
Thanks for the detailed reply. (1)-(3) are fairly clear to me now.
I've started reading http://adam.chlipala.net/cpdt/html/Equality.html and I don't understand why
"generalize (fhapp (fhapp b hls2) hls3)" is needed
this is show at: https://gist.github.com/anonymous/6248428#file-cpdt-equality-v-L619
For pf and pf', I understand why we want to genearlize them -- we want to run "rewrite app_assoc" on them.
However, why are generalizing the (fhapp (fhapp b hls2) hls3) part? (Besides Coq complaining.)
Thanks!
Thanks!
On Fri, Aug 16, 2013 at 6:03 AM, Daniel Schepler <dschepler AT gmail.com> wrote:
On Friday, August 16, 2013 04:26:55 AM t x wrote:Just look at the definition of eq:
> Hi,
> This is my minimal confusion example:
> https://gist.github.com/anonymous/6247310
> The example is a bit silly -- but it comes from a legitimate source,
> studying "Lemma fmiddle_middle" of DepList.v of lambda tamer. (Though I
> might introduced errors.)
> Here are things I am confused on:
> (1) Why does "Fixpoint silly" even get accepted? Why is it that all objects
> of type H can match against "eq_refl" ?
> [ this seems like black magic to me ]
Inductive eq (A : Type) (x : A) : A -> Prop := eq_refl : x = x
Essentially, this is saying that for a fixed type A and element x of A, the
only way to prove anything of the form x = ? is @eq_refl A x; and if you
destruct the equality, you can convert the ? into x (especially if the ? is
just a variable).
(By the way, it's pointless to make silly a Fixpoint -- there's no recursion
here, just a single match.)
"destruct (lem_000 n)" I think first abstracts out the term (lem_000 n) in the
> (2) Why does the "destruct (lem_000 n)" line of lem_002 work? "Print
> lem_000." is a big complicated _expression_. I don't see why it should match
> against eq_refl.
> [ this also seems like black magic to me ]
hypotheses and goal, and then does the destruction. So it's sort of the same
thing as what you did to get to lemma_003.
An easier proof of lemma_003 than what you followed up with would be to start
> (3) Is lemma_003 even provable in Coq? And if so, how do I prove it in Coq?
> [ I'm divided on this. On one hand, it shouldn't be true since not all
> proofs necessarily have to be equal to eq_refl. On the other hand, given
> (1), apparently all proofs are eq_refl, so it's therefore trivially true. ]
with "destruct H" and then either "reflexivity", or "simpl" if you want to see
more clearly why "reflexivity" works.
I'd say read up on dependent pattern matching, and maybe look at the type
> (4) What section of what manual should I read up on clear up these
> knowledge gaps?
signature and definition of "eq_rect".
Now the real kicker is: despite the fact that eq_rect is the only constructor
of equality proofs, it's impossible to prove in general:
forall (A:Type) (x:A) (H:x=x), H = eq_refl.
(!) Technically, the insurmountable obstacle you run into in trying to write
a proof of this is: to do a match on H, you need it to be of the form
match H as H' in (_ = y) return (function of y and H') with ... end
where substituting in H for H' and x for y in the function returns H = eq_refl.
It turns out it's impossible to generalize "H = eq_refl" in such a way that you
can construct a proof of (f x eq_refl).
On the other hand, it *is* possible to prove
forall (A:Type) (x:A) (P : forall y:A, x = y -> Prop),
P x eq_refl -> forall (y:A) (H:x=y), P y H.
But not
forall (A:Type) (x:A) (P : x = x -> Prop),
P eq_refl -> forall (H:x=x), P x H.
I guess what I'm trying to say above is that the freedom to vary the right
hand side of the equality is essential to being able to destruct the equality.
Daniel Schepler
- [Coq-Club] matching on proofs?, t x, 08/16/2013
- [Coq-Club] Re: matching on proofs?, t x, 08/16/2013
- Re: [Coq-Club] matching on proofs?, Daniel Schepler, 08/16/2013
- Re: [Coq-Club] matching on proofs?, t x, 08/16/2013
