- From: mukesh tiwari <mukeshtiwari.iiitm AT gmail.com>
- To: Feró <ferenc.tamasi AT gmail.com>, coq-club AT inria.fr
- Subject: Re: [Coq-Club] Regarding Coq Installation.
- Date: Fri, 16 Aug 2013 17:26:31 +0530
Hi Fero,
Thank you! Now it's working. On Fri, Aug 16, 2013 at 5:12 PM, Feró <ferenc.tamasi AT gmail.com> wrote:
I'd guess the path emacs uses does not contain coqtop.
If you start a shell and print $PATH from emacs, you should see it.
(M-x eshell, then echo $PATH, this works on linux)
> *(load-file
On 8/16/13, mukesh tiwari <mukeshtiwari.iiitm AT gmail.com> wrote:
> Dear All,
> I am trying to learn Coq and I have installed the Coq[1] for OSX 10.8.4.
> Mukeshs-MacBook-Pro:~ mukeshtiwari$ coq
> coq-tex coqc coqchk.opt coqdoc coqtags
> coqtop.byte coqwc
> coq_makefile coqchk coqdep coqmktop coqtop
> coqtop.opt
> Mukeshs-MacBook-Pro:~ mukeshtiwari$ coqtop
> Welcome to Coq 8.4 (September 2012)
> Coq <
> I have installed the Proof-General[2] for Emacs and .emacs configuration is
> Mukeshs-MacBook-Pro:~ mukeshtiwari$ cat .emacs
> (setq make-backup-files nil)
> (setq c-default-style "linux"
> c-basic-offset 4)
> (require 'tramp)
> (setq tramp-default-method "scp")
> (setenv "PATH" (concat "/usr/local/smlnj-110.75/bin:" (getenv "PATH")))
> (setq exec-path (cons "/usr/local/smlnj-110.75/bin" exec-path))
> (setenv "PATH" (concat "/Users/mukeshtiwari/Programming/GHC/ghc-7.6.1/bin:"
> (getenv "PATH")))
> (setq exec-path (cons "/Users/mukeshtiwari/Programming/GHC/ghc-7.6.1/bin"
> exec-path))
> (setenv "PATH" (concat "/Users/mukeshtiwari/.cabal/bin:" (getenv "PATH")))
> (setq exec-path (cons "/Users/mukeshtiwari/.cabal/bin" exec-path))
> (load-file (let ((coding-system-for-read 'utf-8))
> (shell-command-to-string "agda-mode locate")))
> (put 'downcase-region 'disabled nil)
> (custom-set-variables
> ;; custom-set-variables was added by Custom.
> ;; If you edit it by hand, you could mess it up, so be careful.
> ;; Your init file should contain only one such instance.
> ;; If there is more than one, they won't work right.
> '(agda2-include-dirs (quote ("."
> "/Users/mukeshtiwari/Programming/Agda/Library/lib-0.7/src"))))
> (custom-set-faces
> ;; custom-set-faces was added by Custom.
> "/Users/mukeshtiwari/Programming/Coq/ProofGeneral-4.2/ProofGeneral/generic/proof-site.el")
> *> *Welcome to
> (require 'package)
> (add-to-list 'package-archives
> '("melpa" . "http://melpa.milkbox.net/packages/") t)
> (package-initialize)
> (unless (package-installed-p 'scala-mode2)
> (package-refresh-contents) (package-install 'scala-mode2))
> When I am opening a file with .v extension, it showing
> Coq Proof General!> or the homepage*
> Version 4.2.
> (C) LFCS, University of Edinburgh 2012
> Read the Proof General documentation
> Please report problems at Proof General trac
> Visit the Proof General wiki
> *Find out about Emacs on the Help menu -- start with the Emacs Tutorial
> See this screen again with Proof-General -> About*
>> *Starting: coqtop -emacs-U
> I took this simple code from internet
> Example proof script for Coq Proof General.
> example.v,v 11.0 2010/10/10 22:56:58 da Exp
> Module Example.
> Goal forall (A B:Prop),(A /\ B) -> (B /\ A).
> intros A B.
> intros H.
> elim H.
> split.
> assumption.
> assumption.
> Save and_comms.
> End Example.
> and when I am trying to do C-c C-n ( Ctrl-c , Ctrl - n ) , I am getting
> apply: Searching for program: No such file or directory, coqtop*
> I also downloaded CoqIdE_8.4pl2 and copied it to Application. When I am
> launching it, I am not getting any graphical interface but I can see CoqIdE
> in dock. When I am running top, I can see the codide.opt is running but no
> graphical interface!
> 1001 coqide.opt 0.0 00:00.20 2 1 62 147 8620K 8128K 18M
> 49M 2459M 994 994 sleeping 501 8359 648 2014 123
> 2749 5032 1939
> Kindly tell me how to solve this problem ( Pardon me if I sound stupid ).
> Regards,
> Mukesh Tiwari
> [1] http://coq.inria.fr/download
> [2] http://proofgeneral.inf.ed.ac.uk/download
Give me liberty or give me cash!
- [Coq-Club] Regarding Coq Installation., mukesh tiwari, 08/16/2013
- Message not available
- Re: [Coq-Club] Regarding Coq Installation., mukesh tiwari, 08/16/2013
