coq-club - Re: [Coq-Club] Debugging Notations
  • To: t x <txrev319 AT gmail.com>
  • Cc: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Debugging Notations
  • Date: Wed, 28 Aug 2013 15:10:13 -0400
If you have a particular broken notation, you can debug it by making the following straightforward transformation:
Require Import String.
Local Open Scope string_scope.
Notation "'bFoo' A 'eFoo'" := (A, "+", 2) (only parsing).
Eval simpl in (bFoo 2 eFoo).
Eval simpl in (bFoo false eFoo).
I don't know of a good way to do this automatically.
Alternatively, you could protect all of your variables with evars, e.g.,
  Eval simpl in bFoo (_ false) eFoo
and then mentally discard all the ?n. (And, again, the (only parsing) annotation is your friend here.)
-Jason
On Wednesday, August 28, 2013, t x wrote:
Consider the following minimal failure example:
Notation "'bFoo' A 'eFoo'" := (A + 2).
Right now, all I get is: a complaint of "got bool while expectig Z"
This is not particularly useful on larger examples.
The process appears to be:
[1] (bFoo false eFoo)
[2] (false + 2)
[3] type-check
[4] report type check error
Is there a way to put in a [2.5] --> print out what _expression_ is, before it is type checked?
Seeing "(false + 2)" would make debugging much easier than just a "got bool; expected Z"
Thanks!
